Taken 3
Steveredrum
Taken 3
Post by Steveredrum »
Taken USA Retail Blu-ray stops after 20 century fox logo anyone tell me
the correct Playlist for the Blu-ray to work, or there might be a fix I have seen fixes
for Blu-rays to work in the past across the net
Re: Taken 3
Frankly, I have no idea what you're asking. What are you playing the BD with that stops on the logo? What does that have to do with MakeMKV?
Steveredrum
Re: Taken 3
Hi
Yes I have a Backed up copy of Taken 3 USA Retail that stops after the 20 century fox logo
I would like the correct Playlist for it to work correctly.
Then I can make from that a MakeMKV copy for family members thanks
Or this could be the wrong place to ask for this thanks
Re: Taken 3
Was the backup done using MakeMKV? Was the encryption removed during the backup? When it completed, did it pass the final check made by MakeMKV on the file consistency?
When you play from a MakeMKV backup, your player software is navigating the menus found in the raw BD files. If the software stops playing after a while, the problem could be in the file itself OR in the playback software.
The FAQ linked in my signature tells you how to turn on debug logging, so we can see what happens when you do the backup OR open the disk for individual track extraction.
JosephEC
Re: Taken 3
Post by JosephEC »
Getting a weird error I've never seen before with Taken 3. A window pops up and says:
BD+ code was processed but no FUTs were obtained, errors may follow and then it puts a dump file with a ton of stuff in it in my makemkv work folder.
I'm using v1.9.2 win(64) version.
Anyone else getting this?
Re: Taken 3
Forward the dump file to svq@makemkv.com, so that Mike can analyze it and provide a new SVQ file to correct the issue.
JosephEC
Re: Taken 3
Post by JosephEC »
Did just that this morning. :)
jrwalker4
Re: Taken 3
Post by jrwalker4 »
SVQ Dump file forwarded to Mike. Same "No FUTs" message. MakeMKV completed the rip normally but output was pixilated.
JosephEC
Re: Taken 3
Post by JosephEC »
It was horribly pixelated, for sure. Any idea when we may have a fix for this, Mike?
mrkeeling
Re: Taken 3
Post by mrkeeling »
Same problem here. E-mailing tgz file to mike
fesquilin
Re: Taken 3
Post by fesquilin »
i am getting the same error and I am using v:1.9.2 on one machine and 1.9.0 on another machine and both are getting the same error. when I watch it on VLC I get a lot of Pixilation.
jsaddiction
Re: Taken 3
Post by jsaddiction »
I am having the same issues. Any updates or ways I can help with the process?
JosephEC
Re: Taken 3
Post by JosephEC »
Terrific fix! Thank you Mike and all! The extended version is a long rip due to the extraordinarily long segment map, but it is flawless. Again, thanks! :)
bulwei
Re: Taken 3
Post by bulwei »
hy,
unfortunately i am having problems with the german version.
mkv puts out errors starting with
"Fehler 'SCSI-Fehler - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR'..."
and increasing processing time (i interrupted @ estimated another 82hours :D )
thank you for helping,
regards
bulwei
