Cutting MKV
Stryker412
Cutting MKV
Sorry this isn't really MakeMKV related but is there a good free tool to cut a small section of an MKV file? I need to take a 3 minute clip from a 4.5 hour movie.
Wondercow
Re: Cutting MKV
The standard tool for that (and much more) is MKVToolNix.
Re: Cutting MKV
Search for mkvtoolnix. I think you can cut out sections using that.
Otherwise, a tool like Handbrake (handbrake.fr) can be used to transcode a subset of a movie, by chapter, time, or frame number range.
Stryker412
Re: Cutting MKV
Thanks! I never knew the splitting feature was in mkvtoolnix. Got it.
