Problems with direct Bluray access via libmmbd.so
alex123
Post by alex123 »
due to the fact, the direct disc setup via libmmbd.so worked some days before, I'm totally confused.
Since this evening I get error output as follows in any program, that uses libmmbd.so via libaacs and libbdplus:
For example vlc:
index_parse.c:190: indx_parse(): error opening /dev/sr0/BDMV/index.bdmv
index_parse.c:190: indx_parse(): error opening /dev/sr0/BDMV/BACKUP/index.bdmv
[00007f3614000a98] core input error: open of `bluray:///dev/sr0' failed
Current file setting:
lrwxrwxrwx 1 root root    12 Feb 28 02:04 /usr/lib/libaacs.so.0 -> libmmbd.so.0
lrwxrwxrwx 1 root root    12 Feb 28 02:04 /usr/lib/libbdplus.so.0 -> libmmbd.so.0
-rwxr-xr-x 1 root root 34272 Feb 28 02:00 /usr/lib/libmmbd.so.0
brw-rw----+ 1 root optical 11, 0 Feb 28 01:26 /dev/sr0
In /etc/group:
optical:x:93:alex
When I mount the disc previously, everything works fine.
Does anyone know the reason?
Best regards
Alex
Edit:
I found out, that the libbluray library missed the aacs support. Maybe due to an update. Nevertheless, my problem changed to following one:
LANG=C MMBD_TRACE=1 bd_info /dev/sr0
MMBD: MakeMKV v1.9.1 linux(x64-release) started
MMBD: Debug logging enabled, log will be saved as /tmp/MakeMKV-0x76a-1.tmp
MMBD: Opening files on harddrive at /dev/sr0
MMBD: DEBUG: Code 0 at .&:+:k~<nm6=d1H(:213134630
MMBD: DEBUG: Code 0 at .&:+:k~<nm6=d1H(:213131755
MMBD: DEBUG: Code 0 at .&:+:k~<nm6=d1H(:121265407
MMBD: Failed to open disc
aacs.c:288: get_aacs_data(DISC_ID): libaacs not initialized!
dec.c:204: aacs_open() failed!
bdj.c:412: BD-J check: Failed to load JVM library
Re: Problems with direct Bluray access via libmmbd.so
Post by mike admin »
You have to open the directory where disc content is mounted, not the drive device node.
In case someone reads this thread before Mike zaps that last message (and this one, after he gets rid of leoyelverton's), visiting a site that sells copied college thesis papers isn't going to do anything for reading bluray disks.
