~ 1000 hours of audio skew?
Ripman
#1 Post by Ripman » Tue Apr 07, 2015 3:22 pm
I was working with the 2-DVD Apocalypse Now (Complete Dossier) from 2006. It seems like everything went fine. But I got a strange message in the log for each disc indicating about 1,000 hours of audio skew, which is not possible.
Anyway, I checked the resultant mkv's in vlc, and there doesn't seem to be any issues at around the time in question.
I was just surprised by the message, and wanted to make sure I was OK passing these mkv's to HB. I don't think its an issue, just a bit bizzaro.
disc1:
Debug log started at Tue Apr 07 13:34:19 2015 , written by MakeMKV v1.9.1 win(x86-release)
001005:0000 MakeMKV v1.9.1 win(x86-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Documents and Settings\Administrator/MakeMKV_log.txt
003024:1000 Complex multiplex encountered - 18 cells and 6725 VOBUs have to be scanned. This may take some time, please be patient - it can't be avoided.
003028:0000 Title #1 was added (30 cell(s), 1:39:04)
003024:1000 Complex multiplex encountered - 18 cells and 6623 VOBUs have to be scanned. This may take some time, please be patient - it can't be avoided.
003028:0000 Title #2 was added (30 cell(s), 1:20:22)
003025:0000 Title #3 has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #3/1 has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003028:0000 Title #4 was added (1 cell(s), 0:04:03)
003028:0000 Title #5 was added (1 cell(s), 0:02:33)
003028:0000 Title #6 was added (1 cell(s), 0:16:55)
003028:0000 Title #7 was added (1 cell(s), 0:03:02)
003028:0000 Title #8 was added (1 cell(s), 0:05:53)
003028:0000 Title #9 was added (1 cell(s), 0:03:57)
003025:0000 Title #10 has length of 45 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #11 has length of 42 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003028:0000 Title #12 was added (1 cell(s), 0:02:16)
003028:0000 Title #13 was added (1 cell(s), 0:03:15)
003025:0000 Title #14 has length of 62 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #15 has length of 88 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #16 has length of 52 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #17 has length of 55 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003028:0000 Title #18 was added (1 cell(s), 0:02:29)
003025:0000 Title #19 has length of 93 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003028:0000 Title #20 was added (1 cell(s), 0:04:27)
003028:0000 Title #21 was added (1 cell(s), 0:06:35)
005014:0000 Saving 1 titles into directory C:/73d
004007:0010 AV synchronization issues were found in file 'C:/73d/Apocalypse_Now_1_t00.mkv' (title #1)
004008:0010 AV sync issue in stream 1,2 at 0:29:30.658 with duration of 2ms : short audio gap was removed, audio skew is -2ms
004008:0010 AV sync issue in stream 1,2 at 1:01:28.551 with duration of 26.466ms : encountered overlapping frame, audio skew is +24.466ms
004008:0010 AV sync issue in stream 1,2 at 1:17:24.563 with duration of 3528617.859s : short audio gap was removed, audio skew is +12.4ms
005005:0080 1 titles saved
005036:0104 Copy complete. 1 titles saved.
Application exited at Tue Apr 07 14:22:38 2015
disc2:
Debug log started at Tue Apr 07 14:22:51 2015 , written by MakeMKV v1.9.1 win(x86-release)
003024:1000 Complex multiplex encountered - 12 cells and 6516 VOBUs have to be scanned. This may take some time, please be patient - it can't be avoided.
003028:0000 Title #1 was added (24 cell(s), 1:42:43)
003024:1000 Complex multiplex encountered - 12 cells and 6420 VOBUs have to be scanned. This may take some time, please be patient - it can't be avoided.
003028:0000 Title #2 was added (24 cell(s), 1:12:31)
003028:0000 Title #3 was added (1 cell(s), 0:03:48)
003028:0000 Title #4 was added (1 cell(s), 0:04:13)
003028:0000 Title #5 was added (1 cell(s), 0:17:55)
003025:0000 Title #6 has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #7 has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #8 has length of 24 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003028:0000 Title #9 was added (1 cell(s), 0:14:44)
003028:0000 Title #10 was added (1 cell(s), 0:15:20)
003028:0000 Title #11 was added (1 cell(s), 0:03:08)
003028:0000 Title #12 was added (1 cell(s), 0:04:10)
003025:0000 Title #13 has length of 55 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #14 has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
004007:0010 AV synchronization issues were found in file 'C:/73d/Apocalypse_Now_2_t00.mkv' (title #1)
004008:0010 AV sync issue in stream 1,2 at 0:55:36.700 with duration of 3.966ms : encountered overlapping frame, audio skew is +3.966ms
004008:0010 AV sync issue in stream 1,2 at 1:15:18.239 with duration of 3528617.871s : short audio gap was removed, audio skew is +0.2ms
Application exited at Tue Apr 07 14:58:02 2015
Romansh
Re: ~ 1000 hours of audio skew?
#2 Post by Romansh » Wed Apr 08, 2015 12:40 am
Just a guess but it looks like it may be logging a signed number incorrectly, the gap is probably minus a few milliseconds.
