Movies2MKV Converter
rc4ester
Re: Movies2MKV Converter
Post by rc4ester » Mon Mar 23, 2015 2:04 pm
Chetwood wrote:I have two BDs in the queue that are no longer on the harddrive and cannot be deleted from the queue. What gives?
It should remove.. you've tried the "remove all" button?
rc4ester
Post by rc4ester » Mon Mar 23, 2015 2:05 pm
evans036 wrote:i am running windows 7 32bit (and therefore java 32 bit) and i get this error when i try to run the program: "Cannot load 64-bit SWT libraries" . anyone have any ideas?
thanks,
steve
What version do you have of the application? Or is this the first install?
Chetwood
Post by Chetwood » Tue Mar 24, 2015 5:50 am
I'm on 1.9.25, where's the remove all button? "Clear failed conversions" doesn't work. It's stuck on 0% initialising on the first item of them queue and on 22% converting of the second items. Both movies are no longer present because they were on a USB drive that's no longer attached to the PC.
rc4ester
Post by rc4ester » Wed Apr 01, 2015 1:19 am
Chetwood wrote:I'm on 1.9.25, where's the remove all button? "Clear failed conversions" doesn't work. It's stuck on 0% initialising on the first item of them queue and on 22% converting of the second items. Both movies are no longer present because they were on a USB drive that's no longer attached to the PC.
Chetwood,
It should be on the main window. The button says "Clear All conversions" ... That will remove everything in the queue. Does that help? If you are looking to remove one or two.... I believe you can select them and right click. The context menu should have an option to remove the movies selected.
Richard
rc4ester
Post by rc4ester » Wed Apr 01, 2015 1:20 am
Just a heads up. I am working on a windows version. It's been a while in the making, but I am getting much closer to completing the windows application. It should be nearly identical to the Java version, but may have a few extra items that will make it nicer. Plus, I hope that it will run a little faster than the Java version.
Richard
rc4ester
Post by rc4ester » Sat Apr 04, 2015 3:27 pm
The current windows application that I am creating is being written for .Net Framework 4.5. .Net 4.5 can only be run in Windows 7, 8 and Vista SP2. Should I lower to .Net 4.0 to allow for older operating systems? Please let me know your opinion...
Thanks,
Richard
Chetwood
Post by Chetwood » Sun Apr 05, 2015 4:34 am
Dunno why but "Clear All conversions" worked now though it did not before? Anyway, is 4.5 making things easier over 4.0? Then I'd use it.
fexigo
Post by fexigo » Mon Apr 13, 2015 7:31 pm
Hi!
First, thanks for det program!
I need some help with some errors and Output Path.
I get this error when i try to load some movies
And why cant i get the movie into the same folder as the input?? I have been trying to find a solution for many hours now, and cant get it to work.
PLEASE HELP :))
Chetwood
Post by Chetwood » Tue Apr 14, 2015 4:53 am
BTW, how come the font is distorted?
imgur.com/JnPaMzn
fexigo
Post by fexigo » Tue Apr 14, 2015 4:20 pm
Chetwood wrote:BTW, how come the font is distorted?
imgur.com/JnPaMzn
Same with me
rc4ester
Post by rc4ester » Fri Apr 17, 2015 12:18 pm
fexigo wrote:Hi!
PLEASE HELP :))
What are your options set at for input/output directories? You should be able to set up the output directory through the options dialog box. Please show me what you have set and perhaps I could make a few suggestions to get you where you want.
rc4ester
Post by rc4ester » Fri Apr 17, 2015 12:22 pm
fexigo wrote:Hi!
PLEASE HELP :))
This error is caused because it's having a hard time finding what the main title index is of the movie. I have an FTP site set up, if you would like to FTP me the movie, I could trace through and see where the problem is and perhaps fix it or make it work better for everyone. Please PM me if you are interested in this option.
rc4ester
Post by rc4ester » Fri Apr 17, 2015 12:24 pm
imgur.com/JnPaMzn
Same with me
I do not know, I am not controlling the font in any way in the application. Just using the default font.
rc4ester
Post by rc4ester » Fri Apr 17, 2015 12:27 pm
Chetwood wrote:Dunno why but "Clear All conversions" worked now though it did not before? Anyway, is 4.5 making things easier over 4.0? Then I'd use it.
Thanks Chetwood, I'll use 4.5, I believe most people have at least Windows 7 and if they need something down-level... I can try to compile it at the 4.0 level to see if it has any problems.
fexigo
Post by fexigo » Fri Apr 17, 2015 5:23 pm
rc4ester wrote:
fexigo wrote:Hi!
PLEASE HELP :))
I have tried every settings multiple times, but I got it to work one time but im dont remember my settings.So maybe you can come up with a settings that will work for me?? And this is happens to every file I have on my NAS. But i can FTP you the file. No problemo. But I thinks its easier for you just to rename a file?
