Error - Star Wars 1V A New Hope
AdamMason
Post by AdamMason » Wed Apr 01, 2015 1:19 pm
Hope I'm doing this right! Here's the log:
Debug log started at Wed Apr 01 12:04:48 2015 , written by MakeMKV v1.9.1 win(x64-release)
001005:0000 MakeMKV v1.9.1 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\Adam/MakeMKV_log.txt
001003:0020 DEBUG: Code 2 at `|<T"dbf@uC2lNEo:213137827
001003:0020 DEBUG: Code 101016576 at 5C"5|V)_l/F7(vh[%%:213132100
001003:0020 DEBUG: Code 101016576 at 5C"5|V)_l/F7(vh[%%:29393930
002003:0000 Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading 'BD-RE HL-DT-ST BD-RE BH20N C106' at offset '24607651840'
005053:0308 This functionality is shareware. You may evaluate it for 30 days after what you would need to purchase an activation key if you like the functionality. Do you want to start evaluation period now?
005050:0000 Evaluation version, 30 day(s) out of 30 remaining
DAFD=PAAAADAAAAEABDQUEAQEBAQ==
DCE=TwFGD3tIPhlOpFccpMduMMH2iAAeT1vMITdWywRGsKhPNNnnNeQxfrBFvoqzZ/8AOe+lLySp7PNBCBgf5za1x0eEUWt126kN5CIvRnOgzOr+gpvF9xgDyTvXMb6g2abevv607RZSd2wvRYRt2tHTZCJEzWhf3adcrg==
003317:0000 Loaded 37 SVQ file(s)
003326:0000 Processing BD+ code, please be patient - this may take up to few minutes
003324:0000 Processing BD+ code using generic SVQ from builtin/00000.svq
SVQ: generic005 builtin/00000.svq
003328:0000 BD+ code processed, got 1 FUT(s) for 1 clip(s)
DISCID=5806E904234718B00B918A74C40E3CB4889D221E
003025:0000 Title #00720.mpls has length of 35 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00020.mpls was added as title #0
003308:0000 File 00850.mpls (angle 1) was added as title #1
003308:0000 File 00850.mpls (angle 2) was added as title #2
003308:0000 File 00850.mpls (angle 3) was added as title #3
003308:0000 File 00850.mpls (angle 4) was added as title #4
003308:0000 File 00850.mpls (angle 5) was added as title #5
003308:0000 File 00850.mpls (angle 6) was added as title #6
003308:0000 File 00850.mpls (angle 7) was added as title #7
003308:0000 File 00850.mpls (angle 8) was added as title #8
003308:0000 File 00850.mpls (angle 9) was added as title #9
003309:0000 Title 00800.mpls is equal to title 00850.mpls and was skipped
003041:0000 Failed to add angle #2 for title #800
003041:0000 Failed to add angle #3 for title #800
003041:0000 Failed to add angle #4 for title #800
003041:0000 Failed to add angle #5 for title #800
003041:0000 Failed to add angle #6 for title #800
003041:0000 Failed to add angle #7 for title #800
003041:0000 Failed to add angle #8 for title #800
003041:0000 Failed to add angle #9 for title #800
003025:0000 Title #00011.m2ts has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00122.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00123.m2ts has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00720.m2ts has length of 17 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00300.m2ts was added as title #10
003307:0000 File 00301.m2ts was added as title #11
003025:0000 Title #00198.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
001003:0020 DEBUG: Code 233 at Ak5uytahw7J1G8v5P9XyVtTv:0
001003:0020 DEBUG: Code 233 at 6+gIWmhgZC7RGaQby+0yVoOI:0
001003:0020 DEBUG: Code 233 at QAeUE94cYfLJ3KzreEt3np4b:0
001003:0020 DEBUG: Code 233 at 0J/B4DvCKorIVl4lSw+cgutd:0
001003:0020 DEBUG: Code 233 at cpKblGuCLX1LK7CMoGpbEBkQ:0
001003:0020 DEBUG: Code 233 at IuXNeM7/YJwNadJx+bzd2uwa:0
001003:0020 DEBUG: Code 233 at N/aheWvrFmnALZjQ3IAN+Vwd:0
001003:0020 DEBUG: Code 233 at s1u6oIlTERl9KbwxsnDsHzoI:0
001003:0020 DEBUG: Code 233 at 3cX1ts5C6sytgDg921jFXROH:0
001003:0020 DEBUG: Code 233 at awhFdFG7otNRdTxUwoFrMTqz:0
005014:0000 Saving 1 titles into directory C:/Video/A_New_Hope
001003:0020 DEBUG: Code 3221225488 at /@lH%E` NqsJOtl!aS*c=VV)}:121263521
001003:0020 DEBUG: Code 3221225488 at Fc'c!&7>Q@eAw))O:29393953
001003:0020 DEBUG: Code 3221225488 at 5C"5|V)_l/F7(vh[%%:213132100
001003:0020 DEBUG: Code 3221225488 at 5C"5|V)_l/F7(vh[%%:29393930
002003:0000 Error 'OS error - The specified request is not a valid operation for the target device' occurred while reading '\Device\CdRom0' at offset '24607651840'
AV sync issues in C:/Video/A_New_Hope/A_New_Hope_t01.mkv
AV sync in 1,4 at 0:02:26.896 (4.583ms) : encountered overlapping frame, audio skew is +4.583ms
AV sync in 2,3,5 at 0:02:26.896 (15.25ms) : encountered overlapping frame, audio skew is +15.25ms
002003:0000 Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00301.m2ts' at offset '16936009728'
001003:0020 DEBUG: Code 3221225492 at /@lH%E` NqsJOtl!aS*c=VV)}:121263521
001003:0020 DEBUG: Code 3221225492 at Fc'c!&7>Q@eAw))O:29393953
002003:0000 Error 'Scsi error - NOT READY:CANNOT READ MEDIUM - INCOMPATIBLE FORMAT' occurred while reading '/BDMV/STREAM/00301.m2ts' at offset '16950423552'
002003:0000 Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00301.m2ts' at offset '16951406592'
002003:0000 Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00301.m2ts' at offset '16951738368'
002003:0000 Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00301.m2ts' at offset '16955406336'
002003:0000 Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00301.m2ts' at offset '16957046784'
002003:0000 Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00301.m2ts' at offset '16957698048'
002003:0000 Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00301.m2ts' at offset '16958029824'
002003:0000 Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00301.m2ts' at offset '16959338496'
002003:0000 Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00301.m2ts' at offset '16959664128'
002003:0000 Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00301.m2ts' at offset '16962945024'
002003:0000 Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00301.m2ts' at offset '16964579328'
002003:0000 Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00301.m2ts' at offset '16965562368'
002003:0000 Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00301.m2ts' at offset '16966219776'
002003:0000 Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00301.m2ts' at offset '16967202816'
002003:0000 Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00301.m2ts' at offset '16967528448'
002003:0000 Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00301.m2ts' at offset '16968579072'
002003:0000 Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00301.m2ts' at offset '16970870784'
002003:0000 Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00301.m2ts' at offset '16971528192'
002003:0000 Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00301.m2ts' at offset '16971853824'
002003:0000 Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00301.m2ts' at offset '16973168640'
002003:0000 Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00301.m2ts' at offset '16973494272'
002003:0000 Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00301.m2ts' at offset '16974477312'
001003:0020 DEBUG: Code 0 at y6*vfE*%I]?KB[pfW2x&:121263038
001003:0020 DEBUG: Code 0 at jTMn=P#A1I&}jsuIcdAC:213130168
001003:0020 DEBUG: Code 0 at y6*vfE*%I]?KB[pfW2x&:213130559
001003:0020 DEBUG: Code 8288319 at y6*vfE*%I]?KB[pfW2x&:29393286
001003:0020 DEBUG: Code 0 at {Sd%j8Wv.P@.V@bGTwF]7:29399013
001003:0020 DEBUG: Code 0 at W'$mVX$:bonByR?4^QJ:29396414
RH2=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
FS ID=V_MPEG4/ISO/AVC C=2
TI=ZeNpjZICAGTscHRgZCIMGF3NlEJ0N5V9tUAfrI0YvspoGdgYGCxYEfSCWgeElMwMDE0RaAKYWAMPJCL4=
C_00000=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
C_00001=PQL9hM79gAAD//////////wAAAIE4bgIA/////////////////////wQAAAACAAAA8AAAAAEAAAAAAAAIBgEEAACABIAAAGUOQZ4BQAHh+yEWvwAAAwAAAwM7AppgeWThrmFGUh+MJT5KnJiCwsTEtXRmhHzZQWbWnrJqKV07+3sfaZnK6uk0v2FLhM1kEy8I2/mzCBVErYRxI6RZGqe7O4MAFp9f9DakwE03J5RBtAOvL6Tdokk9E9ndSGtstsU8Vk9HrvoYYRyaf7db2lBWlK5B4xBSo0rlneEh9WHk8mm7+yon8xtFTsEsdQv0VHY6610cfK+BhTpSoatuCs9DystKZCFYoKbFLFZOCUeQfbZ8TKUkaQ4RTVe9vEWJtdFylosmHSYcNUQF+FIpiik/yeSE9nGxtfaAeLpW7XOhyn82d8Kzqx6U/39CP0iyTEv+wt8+c23P65vLL/3Ume0RgCM0wPxEZVZDhyPpGSdiwv9vvbIBifbkQ+hTwsdWkt2yS6iR6Fm6VEyjM6j6mh6K9XTSOPSxKz7AyiDaall+SHedGfXQjyCecXOJBQ0GhPlIzS3Dih8qs+sg/vVIsWAwBhFpDjI6xasfD1EdhnCKdfP1dZi6EE1mdLA1BgsYADMgz8l5fUGVuafFf14sPG2d66y7WS3zGaR/FCrDBPTB3notS+LV/2sUSSp+KNgEOWuBLdp+JnC+GSSCYA7gJTZ0rR2YWub++CpXlm+4rB81ptokJ+y7Rr273/eniRcn687mf3l4ccaCrcZG+LzbvAR3TBUM03Tl7GrED/DwD6hme7KQxcajqMtawdU84rjm3Xp0EjiYNnKz17TaBe2OgkTC4dyHJ6jWLyKoAXL2NK5fKMIWMEI220f0OCcroXKQ9dbuvZoYFlNCqbvMrxaH7DLbJqjRyh+0cO7VHDRLkUIvvPVv9CMioB20D9OONEQBcEn28lDKUidrJNLObxNkU0vsPTIJBoyq/UDLJouT7VD7IKnN4eZyLr0+tb0d9+n7NQsU8zaSRLoQgqTcmNqCww381wDg9dteCTHCY4W9Peob0k2z3st7aVPhGNl3s2V9l6gyvDbeBdY7d/XGJtTlN7u2fHSvMQUxdXoGMl53s4hrpc+hBKg47jwrK03CLmocajKtd3K8BzHu9Z/8avks9NNoT7yG0oWeS/QnOr/NOH1deRL7lxG8MKwiLjDY1HoiuA86w40IaOlZTN2riRFpiGlmGp64Vjv5f2TfH0E9X+sv+fTOB+/SWcxAQScx8vmty0ql/3xL4DJrJ9ydHWUeokN/LCh5DsbBRNBLQRGYA8ybSMXHDcp/ZCo/lvyo0prVa1NbecmeXFhHiGq/mqtrw890/bjtSis7bTOOct+4akRHGYEanEfHcNVo/tVlLwQT4J94xJF0BI7bgPW1FncSd4Kupo/eODMia9+nLTUwXEDUJqkLgW+ZDNmrEdTnvRBqiYsXgIVHBI+Bux02ZXo+O83P1ESzCTkL1tO3EvNZ2W9GBlw2eWjA8fpy8gkkCMoCOYEGKHZnqSHjsDMIiI9xOZ10Qdsqo57PKVrZIS0WaEGvDLsp3xQAlzM17DYeEaPfd6775k2rBP80X+xTiEom8Jp2UTPD8UlAHH2A9DDVjZWzAt4xHolrsn9isDN8E1gc41QMlNibqQTKW220yZD8U0YC11pYYvUNRTmggk5A2s4jju15dRFUQ+kIvxAFQOZrCJe8qPvmKrv1/s+5ALwntCBbfhtuif+i9lkXtlbKELmXJ1Kn2lfv4z+k6xfqueVAvDpGXwePbArnmIqDKSQ139eKc5pX1w57B0lsKybg4DhHTCMiklA5Lx1klIeSao1LckL43r82M1CJhP5VIubnNjzZO/5rWkj3m2PqIH0uciO5ZDTgNSwMDvTfsxQNNyOBXhfQaZiVFfrh+EHzJGYbGvL1lRHvSTPsM7HEZLJeGX97sX+5MFpXL0dY49DsXrNyurCHM6m00aLE8quDrqhyc39doWU/b/FxHja7Zhxpe5vdTnvoRldFeDjFpUPN18I55+WI/GT2FOvCbi8wpzPQoyjUIQsxSlzMvBskHhSzxLtZz5YIlqBPYAXGZGWM/FVXYJyypdYE6/WGPoDw5y6WpXcvPZlSJVLRORMs7gz5QMyYsSOb7fJGTHNV1TryyaDONoxQOmu/yNZXZPWVUFPO6kr6jtuo+a27dB0QIz4XNsAxeZ0LeR2R8DjFgAzCjtsvGCqitI7tQ+9ZKwlRpJrWdQ+NkKVZ8p4NYs8EXQ62kNj13zXarHtz9Fjyxk8EX9j0FecHm41QiV2xTygFqdB7KwGt+r3d7CJxRnpGAajUJM75Z3ZVyJHFDgN4VK1IcKSU69mscKHMwzO3e+PJs7wU2blGmguol4j4dUNvWb+UQMrgRgXX6z4ix5mqi410GyxDDco4IAOHd/DXpSU8Ksi3BQja16CE4qnSMEm3uloFEjKOrkzVa5zOyfR2bN6Z4XKTF2Ht4/ZoQZGQUCipm/iv99YNpwLzEGd4X0XFo0eTu9HcKpwGPw+T/zxSaOEklZHH8oEjB+C2c6MGFFM/lUpZRqpqa7cNpsXx60yxvKU+RrIreQ/Ee/vq0/+znv9PPhPAgpwSn0qoCVAS8uHVVmUfSMS9zy38Nw0Yi+f7LkJvBHf068OD1CrrZ6XuI/JszAQ9gIYmNH0Dg2/Y870V25umQlQ5bgXyhrmGvAH1EwMeBXUPiwnR/A65TqFoxlVzCSDpDmdQsDL4DvwHiU7ZNyLmPzKaVbDVhipzA0m1Zy5bIOeLLQBAmFP/cmoR9IzuQgA6SN4X9kxUOIC8F7+KShy4HfMf9abKiood5YGAb0E8Xp6hdra0Rv61O6wZBD40CdMYnIR4bjPKCxHrageVuGl+oD7VhD3UrSZDzMgu8JYLQPuJGPi1Bu+6ntkw2Epk9Y1qy/QCxXmPtDbVqDr8NhS3h/uxpF6oW8YzrGi9tYpZRB/WuLpvBp4xwrmEw+3QMxOkn7H/xAWrhKF3mzN7zhSz89SLNggghZwuL9877XzH1v2ObvlMZdjHCGj10EIVQbKdNSNpwjcFSlrzSv7IncuWJxPtPhCrVZVAULYoGUwzQR2P3UTEMX6FlFVgLubwZeNJpK3neefx+UXj/MOl4sfEalMUVQUSQTzHsOf0UwjKAPnsDcG2c2IZVm4RlBga9XIqBWzGQkiBOlckoSvB+1YxN1wrsV5EG/g2Yfv9PFa9BQ4yNXvydSutYM6a4anoFeK0etXPYNLttex62oKVpp5c+i0U3qSDTG5oTvvrwtNWuNHQYLjbXabRDFjOsznR6g3JHxPPqWmzazlHmiiSiTYWyV7ffumpbCpOUIEZQvgRhScu+FdLreciK3Wa/eaXTbTTeow9+ZUOm0hnZbXmJJVUkCpBelMAtnwvX3vViH2QD+yPF77N7kAzLn/2WZictkDk+u/pSNN1sdoSyTs1ZzZLn5bqdYSSGAs7tR0P7DOQNGPqXClse0PBQMB/GqC3zmruW1iksuH/BA9gSxMTTiy+ksErWbjJndDt3DhDp2yYlF9WU4NCi04RM1X55LjaJQ8Qd9L2bTJXl8C9qWxcPv8DMlJKipOiZjpGlm43CH6oyiqmsTYpuUWoer/93bgdWhOeKr7kHKFnyq/M5MOhoWPR66wnid/YdJk/4vhg/fHMeRFwtofXqKFL1mdoYaAdF1/4efXAHZH8jjxrFSY++ykm/iLyU6qLh441Id0RJoTcGj8dgFTjIAOl8LE83eSvvUZssGX869dgHDqWBrZWuzCJP3r3ZmZPu3aMvGbxC8oyn/MpvCNb0TdsUtxl+h68tVYVH2v9ZQ8jkMc3GmJKDInXO+H26dSNTDsH0VXeVNuITVGv04SMr8Oi2syDetpTiqxC8HgHr79h6R5f/7pcfl+FLTmsJnQ1nnQoc4JKNeEQmffqlK4++/jLeOHTCxoVDyeIvTmH6/5Hndzt8owLaIhYidGrBv8LUTNWvW/t3ydKwc/efIzs/hWihIkTtwJE+OITkw8zoKb4M3X+zSngkeHw85myL8pssOXqHGTtJyxAdnADv8TdAaSwb7MXHxAZ57GXUf9iINRLB2GsMeLTzlEyfpc0BY717GZ1deXQFfFwW9/zdn2wCNnE3LhHmg3qDPcC6EXeCFoOP6AvOzBuY+J7r5bT/o3VS1a5BO+4NX8a+pr5pIwV5GKwFuBFHrNYc2MsLkJLPbEzr+PFW0zF2lytOf8dPL0qhQK9pS/j2x5/pqEg6tolwuDTl2HTRvDsmam0P+fPkzZ7Wx7/8YpxJMB6yN3DKKaE2qaBGqlDxA8UZu/eUE8xjuBBgYCuwGq4AOrQYWtxxiF1d5rXwPDMZi0+jWzxSYulALpK/G+pPoCzwou8iUsOwKmsuBvN3VHfRR5vm/NSn+ePOlbGpJO86axmJ5GEaV6vvKQ6DxbBQKG+04IwA6bHOAMVYOOVLgXr8Xssb99rwMoSpciv18zt4wiQqFojpDO4Ybi2Ju+0OkeAqQw2bq8cOqwYPjwjKia7K+RA411Ds3AiyaxlwuLrtzTULYSkz09ABGTuq7dwg2mePU9DaKLksinrNOwGWz8n9ZR+zogLMrZnrZOmRxGZFSKcukxjADjSsyvNsLMZqOWCwRj0ncid0U8kGr7ZqfYNJ5JulEP0qJL1kyBeLrU+aQ8W4Ifx+YKkAz56dCF3bn5BDSHlq+qngGqMrCN9w5QT/dCwKcCPlmr6WoLKL+VVwvHX4Zoa0F3stpMfLtG/9WvyXMQNLRPus0aWee+tgHdxe8Qqmo9dl8nEqmh8wDbm5bGgmk10EAfiA7tT/wwSLIIqhQOuLGJLnTsnMOz272YkFuWbYV9u1qLfaPw1N+KHeIgLn2+AKgnciD7TfD1WIfbco59bH7UerQd52Ul9jDTBNGt3yz+QNAflwF+MYztmd0MsUfg5AptMy3b28pICxs0CmnOt95KPrl2/Y5R8otlCIpsnmDaFMtgUBdbNvFZ44aDtyFDIeQ2V3WAIOLLaEbrIAmIzMg3PtOqqwHP0kfFK9YCXoNUUEqLm8f7aZv2/IaxLhWynSLboZt/sua/KWC0fi0/gPvafis/9QI0T9Wg50jOAch+kR6H/uWg2LVbxLUg1XZV7Gwoc5HRGoJF3zdo6FkZhp9pHgvl3xHfLNaY0MODwzFxaqf1xO4AC+JtXjqAEoYtgDtRYUN+1Qj+sdIcPZfD5oZKTFh4QCvRWohfuNECBcIMOcoM4OcgF1/CYnRKpznJM/CjCTYWKMLjvIVT2W+Tnt6lzm6B2EvDvYvBshtxSqOF2w/gAFsArflbZRt+nWumic6ZF9EftYY6x20BaB1snIIPphp5SuL7OMMmpOrPE6QF7lrnnMcw0H4DlycWT+bOo2v1jo6/4wgJABvFLDbAJXTFVmIJP7u1cPixqs+JBpbrTOuLEXcDemBUdSMLtPAo445scuIHXkXsxEfwVUf29aIP9MpCFFAs8zynY2FSMXXywJ8v3yTiwVTR6FZwFd6KXfdYQtYi8xbZG
001003:0020 DEBUG: Code 0 at 7k]hu60*4|`Ik;U)a:213131893
001003:0020 DEBUG: Code 0 at 7k]hu60*4|`Ik;U)a:121263406
001003:0020 DEBUG: Code 0 at 7k]hu60*4|`Ik;U)a:29393907
005003:0000 Failed to save title 1 to file C:/Video/A_New_Hope/A_New_Hope_t01.mkv
005004:0080 0 titles saved, 1 failed
Application exited at Wed Apr 01 13:07:26 2015
Re: Error - Star Wars 1V A New Hope
Post by Woodstock » Wed Apr 01, 2015 2:30 pm
Please make sure you email a copy of this log to support@makemkv.com so that Mike sees it sooner.
The debug messages indicate that there is something strange with the data MakeMKV is getting back from the drive, and what work arounds MakeMKV attempted to deal with them.
AdamMason
Post by AdamMason » Thu Apr 02, 2015 12:41 pm
Thanks Woodstock, I have emailed Mike.
It's strange because it ripped all other 5 Star Wars films in the box set.
