Good day and Thank you for this product and forum.
I used this to rip a DVD I had to return to it's owner before I had time to watch it but failed to note where the output was being saved.
Can any one enlighten me please.
Thank you.
Default file location?
Re: Default file location?
The default save location is part of the Preferences. It's been so long since I installed it, I have no idea what the default is, but I think it is in your personal user directory.
It will be on the first page of your Preferences.
Pilgrim
Thank you for that Woodstock. Unfortunately I have been unable to find the file anywhere and will stop wasting time on it.
Perhaps i will stumble upon it one day when walking the dusty halls of the archives.
If you're on Windows 7 or later, open Explorer, click on C:\, and then put "*.mkv" in the search bar. It will find and display all MKV files on drive C.
Pilgrim
Thank you again.
Search shows no saved files.
That was the second thing i tried.
