Wild
Re: Wild
In the log (and display window) you will find a path to a TGZ file that has the information Mike will need to fix this. The log would have also mentioned sending the file to svq@makemkv.com for analysis.
Not sure if that message shows up when you re-rip, but the file should still be there in the designated MakeMKV data directory (that's part of your preferences).
More information: http://www.makemkv.com/svq/
kitzdnm
Re: Wild
Sent the dump log. I hope? Had to find one of my emails, that would send it. I'm new to posting here, but I've been a steady reader here.Woodstock wrote:In the log (and display window) you will find a path to a TGZ file that has the information Mike will need to fix this. The log would have also mentioned sending the file to svq@makemkv.com for analysis.
More information: /svq/
Great place!!
