Correct playlist for Paddington (2014)
Fisk123
Post by Fisk123 » Wed Apr 01, 2015 12:14 pm
Can anyone help me with the correct playlist for the BluRay Paddington ?
Thank you!
Fisk123
Re: Correct playlist for Paddington (2014)
Post by Fisk123 » Wed Apr 01, 2015 2:04 pm
I found it by myself, the first one was correct:
Titelinformationen
Name der Quelldatei: 00009.mpls
Länge: 1:35:12
Anzahl der Kapitel: 12
Segmentanzahl: 15
Segmentkarte: 165,164,168,173,666,163,167,161,171,174,169,162,172,170,166
Name der Ausgabedatei: Paddington_t00.mkv
nickolaush
Post by nickolaush » Wed May 13, 2015 1:52 am
MakeMKV v1.9.2 win(x64-release) started
Title #00010.mpls has length of 66 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00011.mpls was added as title #0
File 00012.mpls was added as title #1
Title #00013.mpls has length of 109 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00004.mpls was added as title #2
Title #00004.m2ts has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00029.m2ts has length of 19 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00090.m2ts has length of 4 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00103.m2ts was added as title #3
Title #00106.m2ts has length of 19 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00112.m2ts has length of 33 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00108.m2ts has length of 109 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00109.m2ts was added as title #4
Title #00110.m2ts has length of 94 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00111.m2ts was added as title #5
File 00116.m2ts was added as title #6
Saving 1 titles into directory Q:/Video/Paddington
**// here's where it goes wrong
Error 'Scsi error - MEDIUM ERROR:ID CRC OR ECC ERROR' occurred while reading '/BDMV/STREAM/00086.m2ts' at offset '22436179968'
Error 'Scsi error - MEDIUM ERROR:1090' occurred while reading '/BDMV/STREAM/00086.m2ts' at offset '22436179968'
Error 'Scsi error - MEDIUM ERROR:ID CRC OR ECC ERROR' occurred while reading '/BDMV/STREAM/00086.m2ts' at offset '22437556224'
Error 'Scsi error - MEDIUM ERROR:ID CRC OR ECC ERROR' occurred while reading '/BDMV/STREAM/00086.m2ts' at offset '22438017024'
Error 'Scsi error - MEDIUM ERROR:ID CRC OR ECC ERROR' occurred while reading '/BDMV/STREAM/00086.m2ts' at offset '22475304960'
Error 'Scsi error - MEDIUM ERROR:1090' occurred while reading '/BDMV/STREAM/00086.m2ts' at offset '22475304960'
Error 'Scsi error - MEDIUM ERROR:ID CRC OR ECC ERROR' occurred while reading '/BDMV/STREAM/00086.m2ts' at offset '22475317248'
Error 'Scsi error - MEDIUM ERROR:ID CRC OR ECC ERROR' occurred while reading '/BDMV/STREAM/00086.m2ts' at offset '22475341824'
Failed to save title 0 to file Q:/Video/Paddington/Paddington_t00.mkv
0 titles saved, 1 failed
Post by Woodstock » Wed May 13, 2015 2:24 pm
The CRC errors are a problem with reading the disk itself. Try cleaning it, because finger prints will do that sort of thing.
spindledk
Post by spindledk » Tue Jun 02, 2015 4:56 am
Fisk123 wrote:I found it by myself, the first one was correct:
Titelinformationen
Länge: 1:35:12
Segmentanzahl: 15
Could you please tell how you found it?
Thanks.
DrMagicWolf
Post by DrMagicWolf » Wed Feb 24, 2016 4:26 pm
Titelinformationen
Länge: 1:35:12
Segmentanzahl: 15
I thought I had found the correct one as well (taking the first one), however at around minute 6 and minute 29 everything got muddled up, some scenes were suddenly mixed in between others, so I guess it's not the right one after all...
Has anyone found the correct playlist already in the meantime?
EDIT: After hours of trying, analyzing and importing loads of tracks with different playlists, I finally found the correct playlist:
Title information
Name: Paddington (English)
Source file name: 00561.mpls
Duration: 1:35:12
Chapters count: 12
Segment count: 15
Segment map: 165,168,173,164,666,171,161,163,174,167,169,162,172,170,166
File name: Paddington_t106.mkv
I hope this helps anyone trying to find the right playlist.
PapaQ
Post by PapaQ » Wed Oct 29, 2025 12:15 am
A very delayed addition to this thread. I've found the correct playlist for the Nordic blu-ray (Swedish, Danish, Norwegian, Finnish languages).
Source file name: 00213.mpls
Duration: 1:35:05
Chapters count: 8
Segment count: 15
Segment map: 108,106,689,1,104,102,112,105,111,107,115,114,116,103,110
File name: Paddington_t41.mkv
