Can I have assistance please on the possible playlists for Wild Card released 2015
Kind Regards,
Nivick
Correct playlist for Wild Card (2015)
Re: Correct playlist for Wild Card (2015)
If you are running Windows, you can use Google to search for "bluray playlist obfuscation youtube", to find video instructions on how to find the proper file for the version of the disk that YOU have.
Many of these disks that have the hundreds of titles have a different correct title, depending upon where you bought the disk. That is, the Amazon version will be different Target's, Best Buy's, or where ever.
nivick
Cheers for the update.
I will follow your instructions.
dark_slayer
Would anyone helpful reply with the mpls that worked for them, thanks
nivick
I can start this on off hopefully with 507 for the disc I have...
bradleyc
Is there any way to do this on a Mac? I have the programs "Blu-Ray Player" from Macgo, as well VLC, although I haven't been successful with either of these.
goingbust
Interesting, but it requires PowerDVD and apparently AnyDVDHD. Since when is this the forum for those products? I like his technique, it is a nice general technique, but I don't have a commercial software BD player. That's the whole reason I use MakeMKV to rip BDs, so I can play them in VLC, a non-commercial player. Is there an alternative? Maybe one of you suckers bought that software and will just tell me.Woodstock wrote:If you are running Windows, you can use Google to search for "bluray playlist obfuscation youtube", to find video instructions on how to find the proper file for the version of the disk that YOU have.
NEO Dan
Source file name: 00507.mpls
Duration: 1:32:20
Chapters count: 16
Segment count: 21
Segment map: 513,514,519,505,515,517,520,518,512,79,506,516,501,508,510,507,503,502,511,509,504
File name: WILD_CARD_t157.mkv
The two forced subtitles for the English language are empty...
Duration: 1:32:20
Chapters count: 16
Segment count: 21
The video I watched did not require AnyDVD, just "something" that can play BD disks directly, and PowerDVD is probably the most popular. Free versions of that come with most retail packaged BD drives. I don't use it because it installs drivers that interfere with MakeMKV.goingbust wrote:Interesting, but it requires PowerDVD and apparently AnyDVDHD. Since when is this the forum for those products? I like his technique, it is a nice general technique, but I don't have a commercial software BD player. That's the whole reason I use MakeMKV to rip BDs, so I can play them in VLC, a non-commercial player. Is there an alternative? Maybe one of you suckers bought that software and will just tell me.
I know the METHOD works, because I used it to troubleshoot an issue with some other video.
bradleyc
I just did it the old fashioned way (watched 30 minutes on my TV and then doubled checked each title until I found the right one) and, for me, it was the first title.
Source file name: 00006.mpls
Duration: 1:32:20
Chapters count: 16
Segment count: 21
Segment map: 513,514,519,505,517,520,515,518,512,516,506,501,510,79,508,507,511,503,502,509,504
File name: WILD_CARD_t00.mkv
Hopefully this helps someone else out. Take care.
Duration: 1:32:20
Chapters count: 16
Segment count: 21
dark_slayer
NEO Dan wrote:Name: WILD CARD
Duration: 1:32:20
Chapters count: 16
Segment count: 21
Thanks both, I must of had the same discnivick wrote:I can start this on off hopefully with 507 for the disc I have...
dashocker
Any confirmation on correct MPLS?
johng
Can you elaborate on what the issue is with installing PowerDVD and using MakeMKV? It seems that others on this forum have done this and haven't reported any problems???
Woodstock wrote:The video I watched did not require AnyDVD, just "something" that can play BD disks directly, and PowerDVD is probably the most popular. Free versions of that come with most retail packaged BD drives. I don't use it because it installs drivers that interfere with MakeMKV.goingbust wrote:Interesting, but it requires PowerDVD and apparently AnyDVDHD. Since when is this the forum for those products? I like his technique, it is a nice general technique, but I don't have a commercial software BD player. That's the whole reason I use MakeMKV to rip BDs, so I can play them in VLC, a non-commercial player. Is there an alternative? Maybe one of you suckers bought that software and will just tell me.
johng
This technique only requires PowerDVD and has nothing to do with AnyDVDHD.
goingbust wrote:Interesting, but it requires PowerDVD and apparently AnyDVDHD. Since when is this the forum for those products? I like his technique, it is a nice general technique, but I don't have a commercial software BD player. That's the whole reason I use MakeMKV to rip BDs, so I can play them in VLC, a non-commercial player. Is there an alternative? Maybe one of you suckers bought that software and will just tell me.Woodstock wrote:If you are running Windows, you can use Google to search for "bluray playlist obfuscation youtube", to find video instructions on how to find the proper file for the version of the disk that YOU have.
Pulled out the copy of PowerDVD 10 I have, and installed it. It's coming back out, because I now remember WHY I removed it in the first place. PowerDVD insists on setting region codes on my drives, which do not currently have them, before it will use them to play content. Not acceptable for me. Even though MakeMKV can work around the region coding, I'd rather not have it set anyway.Woodstock wrote:The video I watched did not require AnyDVD, just "something" that can play BD disks directly, and PowerDVD is probably the most popular. Free versions of that come with most retail packaged BD drives. I don't use it because it installs drivers that interfere with MakeMKV.
