It acts like everything is normal, but aborts immediately after it starts to run. Here is the output log:
MakeMKV v1.9.1 darwin(x86-release) started
Optical drive "BD-ROM hp DVDWBD TS-LB23L 0600d" opened in OS access mode.
File 00800.mpls was added as title #0
Title #00082.mpls has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00003.mpls has length of 115 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00451.mpls was added as title #1
Title 00700.mpls is equal to title 00451.mpls and was skipped
File 00819.mpls was added as title #2
File 00820.mpls was added as title #3
Title #00002.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00006.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00007.m2ts has length of 55 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00008.m2ts has length of 22 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00009.m2ts was added as title #4
Title #00011.m2ts has length of 21 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00014.m2ts has length of 17 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00015.m2ts was added as title #5
Title #00016.m2ts has length of 22 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00021.m2ts has length of 22 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00022.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00023.m2ts has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00024.m2ts has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00025.m2ts has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00276.m2ts was added as title #6
Error 'OS error - (ipc/send) invalid destination port' occurred while reading '/BDMV/STREAM/00277.m2ts' at offset '393216'
Failed to decode audio/video data for title #7 - invalid mux or internal error, title skipped.
Title #00277.m2ts was skipped
Title #00278.m2ts has length of 112 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Error 'OS error - (ipc/send) invalid destination port' occurred while reading '/BDMV/STREAM/00279.m2ts' at offset '0'
Title #00279.m2ts was skipped
File 00280.m2ts was added as title #7
Title #00281.m2ts has length of 40 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00282.m2ts has length of 104 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00283.m2ts has length of 105 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00284.m2ts was added as title #8
Error 'OS error - (ipc/send) invalid destination port' occurred while reading '/BDMV/STREAM/00285.m2ts' at offset '0'
Title #00285.m2ts was skipped
Title #00286.m2ts has length of 56 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Error 'OS error - (ipc/send) invalid destination port' occurred while reading '/BDMV/STREAM/00287.m2ts' at offset '0'
Title #00287.m2ts was skipped
Error 'OS error - (ipc/send) invalid destination port' occurred while reading '/BDMV/STREAM/00288.m2ts' at offset '0'
Title #00288.m2ts was skipped
Error 'OS error - (ipc/send) invalid destination port' occurred while reading '/BDMV/STREAM/00289.m2ts' at offset '0'
Title #00289.m2ts was skipped
File 00290.m2ts was added as title #9
Title #00291.m2ts has length of 98 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Error 'OS error - (ipc/send) invalid destination port' occurred while reading '/BDMV/STREAM/00292.m2ts' at offset '0'
Title #00292.m2ts was skipped
Title #00293.m2ts has length of 95 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00272.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00273.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00274.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00275.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Saving 1 titles into directory /Users/jonro/Movies/The_Prince
Error 'OS error - (ipc/send) invalid destination port' occurred while reading '/BDMV/STREAM/00012.m2ts' at offset '0'
Failed to save title 0 to file /Users/jonro/Movies/The_Prince/The_Prince_t00.mkv
0 titles saved, 1 failed
The Prince
Re: The Prince
Error 'OS error - (ipc/send) invalid destination port' occurred while reading '/BDMV/STREAM/00277.m2ts' at offset '393216'Make sure that it is plugged into a port with adequate power available. If it is NOT plugged DIRECTLY into the computer, make sure that the hub it is plugged into has external power. Hubs without their own power supply split the power they get from the computer (2.5 watts max for USB2) between accessories, and that doesn't work. Computer ports "almost always" have full specification power available, if you're using a desktop computer.
Some of these drives come with a "two head" USB cable, which is needed for high-speed applications - it should be plugged into two POWERED ports (either on the computer or on a powered hub) to run at full speed.
And no, I don't know of a setting to prevent MakeMKV from running it up to full speed.
jonro
Re: The Prince
It's plugged into a powered hub, and has been working well for a couple of years like this. I unplugged both cables, data and power, and after plugging them back in, lo and behold, it's now ripping. Thanks.
