Big Hero 6, Son of a Gun, Dumb and Dumber To...
djmalcom
Post by djmalcom » Wed Apr 01, 2015 1:09 am
All get failures...here is the log from Big Hero 6.
Any help would be appreciated.
Saving 1 titles into directory H:/HD MOVIES/big hero 6
DEBUG: Code 0 at jTMn=P#A1I&}jsuIcdAC:121262762
The source file '/BDMV/STREAM/00300.m2ts' is corrupt or invalid at offset 5385418752, attempting to work around
The source file '/BDMV/STREAM/00300.m2ts' is corrupt or invalid at offset 5385424896, attempting to work around
The source file '/BDMV/STREAM/00300.m2ts' is corrupt or invalid at offset 5385431040, attempting to work around
The source file '/BDMV/STREAM/00300.m2ts' is corrupt or invalid at offset 5385437184, attempting to work around
The source file '/BDMV/STREAM/00300.m2ts' is corrupt or invalid at offset 5385443328, attempting to work around
The source file '/BDMV/STREAM/00300.m2ts' is corrupt or invalid at offset 5385449472, attempting to work around
The source file '/BDMV/STREAM/00300.m2ts' is corrupt or invalid at offset 5385455616, attempting to work around
The source file '/BDMV/STREAM/00300.m2ts' is corrupt or invalid at offset 5385461760, attempting to work around
The source file '/BDMV/STREAM/00300.m2ts' is corrupt or invalid at offset 5385467904, attempting to work around
The source file '/BDMV/STREAM/00300.m2ts' is corrupt or invalid at offset 5385474048, attempting to work around
DEBUG: Code 0 at jTMn=P#A1I&}jsuIcdAC:121262532
DEBUG: Code 0 at jTMn=P#A1I&}jsuIcdAC:121262647
DEBUG: Code 0 at y6*vfE*%I]?KB[pfW2x&:213130559
DEBUG: Code 2629626 at y6*vfE*%I]?KB[pfW2x&:29393286
DEBUG: Code 0 at {Sd%j8Wv.P@.V@bGTwF]7:29399013
Failed to save title 2 to file H:/HD MOVIES/big hero 6/Big_Hero_6_t02.mkv
0 titles saved, 1 failed
Re: Big Hero 6, Son of a Gun, Dumb and Dumber To...
Post by Woodstock » Wed Apr 01, 2015 1:29 am
Multiple disks from different publishers with the same type of errors would lead me to think about cleaning the drive.
But only Mike can decode the debug codes to say for sure. I recommend following the instructions in the FAQ linked in my signature and send the files to support@makemkv.com so that he can look at them.
