The Shining (2007) 'MEDIUM ERROR:L-EC'
jFiveNYC
#1 Post by jFiveNYC » Mon Mar 30, 2015 6:36 am
The Shining Blu-ray
Studio: Warner Home Video
DVD Release Date: October 23, 2007
Run Time: 144 minutes
ASIN: B000UJ48WC
Re: Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR'
Encountered this issue today which resulted in the application crashing, TWICE. Should anyone from MakeMKV want my OS X crash reports, both are available over private email. After sync the OS X system clock, rebooting, sync again, and second reboot, the title was saved successfully.
Error Log #1
Debug log started at Mon Mar 30 03:01:37 2015 , written by MakeMKV v1.9.1 darwin(x86-release)
001005:0000 MakeMKV v1.9.1 darwin(x86-release) started
001004:0000 Debug logging enabled, log will be saved as /Users/bk201/MakeMKV_log.txt
002010:0000 Optical drive "BD-RE ASUS BW-12B1ST   a 1.00d" opened in OS access mode.
001003:0020 DEBUG: Code 0 at CWNe.K'>B [Jt+JG><.M0\n)}:121263153
DEBUG: Code 0 at +%ipU{2e&m~4);#?O$F#Q JR_:29394160
001003:0020 DEBUG: Code 2 at +:}Eom,ix5a%&+*8:213137827
001003:0020 DEBUG: Code 100864261 at 0FMP3@O.n~:GTxM+v(:213132100
001003:0020 DEBUG: Code 100864261 at 0FMP3@O.n~:GTxM+v(:29393930
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00000.m2ts' at offset '23620521984'
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00000.m2ts' at offset '6125574144'
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00039.m2ts' at offset '321835008'
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00039.m2ts' at offset '1843279872'
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00039.m2ts' at offset '1790736384'
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00039.m2ts' at offset '965658624'
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00039.m2ts' at offset '870703104'
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00039.m2ts' at offset '1271629824'
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00039.m2ts' at offset '217337856'
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00039.m2ts' at offset '1972604928'
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00039.m2ts' at offset '393424896'
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00039.m2ts' at offset '1007241216'
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00039.m2ts' at offset '0'
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00039.m2ts' at offset '6144'
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00039.m2ts' at offset '12288'
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00039.m2ts' at offset '18432'
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00004.m2ts' at offset '720814080'
DAFD=PAAAADAAAAEABDQkEHwECAQ==
DCE=K3PG0e1w62EnWUGVro03EUoOj78xgmULwBbDgRYyVJf3zzY8c00JYwNm5UrpowG9KWbRjafwp7+4eNKF51cMAUBGmYnkN6CfL5P/8Sf7e+sNXvl2x2M8REdQb3RcArQ0Tmc6P0begLtLgXdDmCaoJTyDch7bhqhPrA==
DCE=SvQRl+DAz4f6hO9UCl5DcO064xKqEp4HwacfhJb4MDNAP39Jcbx7jpha0UdQkN45B77Ofn+UEOwPx1H4TD4ojdXozlFK/RhTr/pq1EKWzGUQyUJyBL///o1iXfGgZ8NdotksLDj0BuYr2g+hc5GX7lGtmlCWbT5K/w==
DISCID=6AFF420869157CF15668ABF81812F5640D5FD4BC
003307:0000 File 00000.mpls was added as title #0
003307:0000 File 00002.m2ts was added as title #1
003307:0000 File 00003.m2ts was added as title #2
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00004.m2ts' at offset '0'
001003:0020 DEBUG: Code 0 at |3o-|,cAfBpKz>>&|[:29393677
001003:0020 DEBUG: Code 0 at }5r7u7vUaM+cU_Xb:213131479
001003:0020 DEBUG: Code 0 at q4YtG5csQsi/1?V:29402670
001003:0020 DEBUG: Code 0 at dl{NJwRQ3I/j!eDG:29407730
003016:0000 Title #00004.m2ts was skipped
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00005.m2ts' at offset '0'
003016:0000 Title #00005.m2ts was skipped
003025:0000 Title #00006.m2ts has length of 92 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00033.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00034.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00036.m2ts has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00037.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00039.m2ts was added as title #3
Error Log #2
Debug log started at Mon Mar 30 05:10:29 2015 , written by MakeMKV v1.9.1 darwin(x86-release)
DCE=fyRPQTk1u8MeNICEFNdRS+tmyrwVSr7nzUGMsNOfcmbeuexRrc0yjHkqV1G51y+0HfpM1/vf/0pkaIeqD0A1idK+T4aVdszKajAKf1gkC5inu/a32Ul5NIiiO/hyAVBE+FUUPsLm7pFa1zxUPuvUhHIECk6oYswovA==
DCE=VeufenMzhXSPwLEQZkL4eL+/NuQxbvKjCxxGwOFu47P5tGbXi2Nx1QdlZitL1X11ncwBfm6e60NBLkGnhJSn7UQKLevuCshHAmmyWVKNVaMeuV12fc1p8hTEGS2fIr7c1St0EmQYQWP427YXT6rKcMKkrV2ios6E0w==
003307:0000 File 00004.m2ts was added as title #3
003307:0000 File 00005.m2ts was added as title #4
003307:0000 File 00039.m2ts was added as title #5
005014:0000 Saving 1 titles into directory /Volumes/Shibuya/MakeMKV/The Shining
001003:0020 DEBUG: Code 1073741829 at F|[Xas[#+W`~J6Tx:29393953
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00000.m2ts' at offset '22159749120'
001003:0020 DEBUG: Code 0 at J-a:X:9V#h[dZ4nS-Gvd:121263038
001003:0020 DEBUG: Code 0 at HC6{7s`F@PLMP((8P{+K:213130168
001003:0020 DEBUG: Code 0 at J-a:X:9V#h[dZ4nS-Gvd:213130559
001003:0020 DEBUG: Code 10820190 at J-a:X:9V#h[dZ4nS-Gvd:29393286
001003:0020 DEBUG: Code 0 at ~dgUti*1.7aXWJeg^ovm\:29399013
001002:0020 LIBMKV_TRACE: Exception: Error in p->FetchFrames(1,false)
005003:0000 Failed to save title 0 to file /Volumes/Shibuya/MakeMKV/The Shining/title00.mkv
005004:0080 0 titles saved, 1 failed
Error Log #3 (SUCCESS AFTER TIME SYNC AND TWO REBOOTS
Debug log started at Mon Mar 30 06:11:24 2015 , written by MakeMKV v1.9.1 darwin(x86-release)
DCE=C+gX4mSGKyjZOzEWPUkN0OeeUILokSH7mDFh8+Uhr+1MLmPIXu6lAplr+n6Qil2BQDp3FusMKWLtUUgLcvPNmQVhLEmj6zDHHS6CGRiOG45TM366aGTonQs/MtwfAjhsNsSR/NV6tDq1IFQPkFYDyJkE59rkOPMAvA==
DCE=8heGRsSuYimBg4kV61WYUZipugddCl4tGbHFS4Jq2CdiWIYkydy2ie4iOV2KuL08nG0gm/iPpNLuEE6W1ukqq7Ut6IcUriv/yl+zEFyazCjOSx6x+dlZW0ImikgKr8vDhMy4lGybtpWvboqpIq1XdVidqll5aMcp4g==
001003:0020 DEBUG: Code 0 at @t,]!2n\#cM3QGf\:29396529
002003:0000 Error 'Internal error - Operation was cancelled (112)' occurred while reading '/BDMV/STREAM/00005.m2ts' at offset '0'
002003:0000 Error 'Internal error - Operation was cancelled (112)' occurred while reading '/BDMV/STREAM/00039.m2ts' at offset '0'
003016:0000 Title #00039.m2ts was skipped
DCE=Ly8vLy+Hf8YIjz2SSn5cURtw22hTOX8l+48aeQYGlKlE4C9Y8AKDILsYOatxRkfQCW35SbXi9QqrJrok0cIPBkH+ErAwPU9/S+Q/HZUHwkfc22XMxNfQGcACgDh3cFrpCbiXUteqWIz9FVr4q1EHtvwO9wzNSuUSKw==
DCE=Ly8vLy+Hf8YIGW0KssYY/iP+i51T6PE9zttsdIwGlKlE4C9Y8AKDILsYOatxRkfQCW35SbXi9QqrJrok0cIPBkH+ErAwPU9/S+Q/HZUHwkfc22XMxNfQGcACgDh3cFrpCbiXUteqWIz9FVr4q1EHtvwO9wzNSuUSKw==
004001:0000 Forced subtitles track #4 turned out to be empty and was removed from output file
005005:0080 1 titles saved
005036:0104 Copy complete. 1 titles saved.
END. Thanks Mike.
Ripman
Re: The Shining (2007) 'MEDIUM ERROR:L-EC'
#2 Post by Ripman » Mon Mar 30, 2015 2:34 pm
I used MakeMKV 1.9.1 for the same BD under Win 8.1 and had no issues at all.
Debug log started at Sun Feb 15 15:13:42 2015 , written by MakeMKV v1.9.1 win(x86-release)
001005:0000 MakeMKV v1.9.1 win(x86-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Documents and Settings\Administrator/MakeMKV_log.txt
005072:0000 Backing up disc into folder "C:/91/SHINING"
DAFD=PAAAADAAAAEABDQkEFgACAQ==
DCE=bfv3u4ou3NRbaf63iEYn7WzUcwfdm+Ld+314jbKiTLMWcH5V5qBKREBmAJz8h5k1HqEw8uip3BodutR8w0zpPDRjNK7bIIP5x9spYmDs624fofvwQtauerumqM9DlCZWL5yrAvitu5K2DV3w2f7YOlYu62D9jcNhEQ==
DCE=ffHRAj9RhVhULXDURbhHi+DzUNfsBRKL6N0OvG+RLlChzAo19rtDSgofEjyQVMcYja/xpBtL2o6x+1LIaYsY12S79+skXb2+IkDg/7fDvdzr8TM5IhnIOVc4uQ9eDZKhPQjJSFHPexWenN/pKrqskybKT+BElqLcTA==
005070:0080 Backup done
005081:0104 Backup done.
Application exited at Sun Feb 15 15:55:37 2015
Debug log started at Sun Feb 15 21:02:42 2015 , written by MakeMKV v1.9.1 win(x86-release)
003006:0000 Opening files on harddrive at C:/91/SHINING
DISCID=3F68F77F93225BACE497715317708AED832825C4
005014:0000 Saving 1 titles into directory C:/91
004001:0000 Forced subtitles track #5 turned out to be empty and was removed from output file
Application exited at Sun Feb 15 21:50:34 2015
I subsequently used HB with an RF=18/high profile/h.264/4.1/slow, and the resultant MKV was literally perfect. I also converted the LPCM track to flac in that HB session.
