DTS
Badboyztn
DTS
Post by Badboyztn » Sun Mar 29, 2015 4:25 am
Just a quick question from a makemkv noob. I have ripped 3 movies and I click the DTS-HD MA button before ripping the file. When I play back through Plex or Kodi, my HK receiver only says DTS and not DTS-HD MA and the little speakers graphic does not show on my receiver. Is this the way it's supposed to work or do I need to enable a setting somewhere?
Re: DTS
Post by Woodstock » Sun Mar 29, 2015 3:13 pm
Not all programs can handle DTS-HD directly.
If you want to have the DTS core (lossy) audio available, it will be a separate track from the DTS-HD (lossless) track. Have you switched to the second track during playback?
Also, with both Plex and Kodi, you have to make sure they aren't transcoding the audio. Part of their function is to make media files compatible with the playback hardware....
Badboyztn
Re: DTS
Post by Badboyztn » Sun Mar 29, 2015 7:32 pm
There is only 1 audio track because I uncheck them all except for the DTS-HD MA. If I unchecked Pass Thru on Kodi, my receiver then says Multi-Ch PCM
maiden_trooper
Re: DTS
Post by maiden_trooper » Fri May 08, 2015 10:11 am
Then, Kodi is decoding the DTS-HDMA track into LPCM and passing it to your receiver.
Since, LPCM, like DTS-HDMA is lossless, IMHO, this is perfectly okay assuming that Kodi is correctly decoding DTS-HDMA to LPCM without introducing artefacts of its own.
