Does MakeMKV can do an Blurry ISO file ?
Anode
#1 Post by Anode » Sat Mar 28, 2015 1:23 pm
Hi all, first and bravo for this great app...
I just would want to now if MKV can do an Bluray ISO file ?
Thanks by advance.
Anode
Re: Does MakeMKV can do an Blurry ISO file ?
#2 Post by Woodstock » Sat Mar 28, 2015 2:28 pm
No, MakeMKV does not do any type of ISO files. The Backup function can copy the BD structure to your hard drive, removing the encryption at the same time if you choose, but that is not the same thing as an ISO, and you would need some other program to create one from the file structure.
Anode
#3 Post by Anode » Sun Mar 29, 2015 11:42 am
Hi and many thanks to you for your quickly reply.
Can I ask you a last question ? how can do for do a backup ? the ICON is off !!
Thanks by advance.
Anode
#4 Post by Woodstock » Sun Mar 29, 2015 3:29 pm
The backup icon only comes on for BD; it is not available for DVD. And if you click on the big "OPEN" button (looks like a disk in the middle of the screen), you've moved down a different path from backup, so it becomes unavailable until you close the disk (File->Close).
Anode
#5 Post by Anode » Sun Mar 29, 2015 3:39 pm
Thanks for all everything is clear...
Best regards.
Anode
