I've previously used AnyDVD HD to backup the bluray Casablanca to the hard drive, and am now trying to use MakeMKV to extract a few MKVs from it. There are a number of titles which I'm after that don't appear within MakeMKV at all, the main one I'm after is playlist 68 (excluding the main title which is playlist 0). I've used BDInfo to look a bit deeper into the structure and it seems that playlist 68 is comprised of the stream file 00190.M2TS, but neither does this appear in MakeMKV.
Why is MakeMKV missing quite a number of titles? Also, why are certain titles not listed as playlists, but m2ts files. Here are the following logs:
BDInfo
MakeMKVInfo
MakeMKVDebugLog
Thanks.
MakeMKV not loading all playlists
- Contact:
Re: MakeMKV not loading all playlists
Looks like a bug. Please send all CLPI and MPLS files to support@makemkv.com per instructions at /faq/item/8/catid/6OnEAS wrote:Why is MakeMKV missing quite a number of titles?
This happens if MPLS file is "useless" - when it references a single M2TS file, with all streams and no chapters. In this case MPLS wrapping adds no value, so M2TS file is parsed directly.OnEAS wrote:Also, why are certain titles not listed as playlists, but m2ts files.
