Correct playlist for Wild Card (2015)
nivick
Post by nivick »
Can I have assistance please on the possible playlists for Wild Card released 2015
Kind Regards,
Nivick
Re: Correct playlist for Wild Card (2015)
If you are running Windows, you can use Google to search for "bluray playlist obfuscation youtube", to find video instructions on how to find the proper file for the version of the disk that YOU have.
Many of these disks that have the hundreds of titles have a different correct title, depending upon where you bought the disk. That is, the Amazon version will be different Target's, Best Buy's, or where ever.
nivick
Post by nivick »
Cheers for the update.
I will follow your instructions.
dark_slayer
Post by dark_slayer »
Would anyone helpful reply with the mpls that worked for them, thanks
nivick
Post by nivick »
I can start this on off hopefully with 507 for the disc I have...
bradleyc
Post by bradleyc »
Is there any way to do this on a Mac? I have the programs "Blu-Ray Player" from Macgo, as well VLC, although I haven't been successful with either of these.
goingbust
Post by goingbust »
Woodstock wrote:If you are running Windows, you can use Google to search for "bluray playlist obfuscation youtube", to find video instructions on how to find the proper file for the version of the disk that YOU have.
Interesting, but it requires PowerDVD and apparently AnyDVDHD. Since when is this the forum for those products? I like his technique, it is a nice general technique, but I don't have a commercial software BD player. That's the whole reason I use MakeMKV to rip BDs, so I can play them in VLC, a non-commercial player. Is there an alternative? Maybe one of you suckers bought that software and will just tell me. :D
NEO Dan
Post by NEO Dan »
Source file name: 00507.mpls
Duration: 1:32:20
Chapters count: 16
Segment count: 21
Segment map: 513,514,519,505,515,517,520,518,512,79,506,516,501,508,510,507,503,502,511,509,504
File name: WILD_CARD_t157.mkv
The two forced subtitles for the English language are empty...
goingbust wrote:Interesting, but it requires PowerDVD and apparently AnyDVDHD. Since when is this the forum for those products? I like his technique, it is a nice general technique, but I don't have a commercial software BD player. That's the whole reason I use MakeMKV to rip BDs, so I can play them in VLC, a non-commercial player. Is there an alternative? Maybe one of you suckers bought that software and will just tell me. :D
The video I watched did not require AnyDVD, just "something" that can play BD disks directly, and PowerDVD is probably the most popular. Free versions of that come with most retail packaged BD drives. I don't use it because it installs drivers that interfere with MakeMKV.
I know the METHOD works, because I used it to troubleshoot an issue with some other video.
bradleyc
Post by bradleyc »
I just did it the old fashioned way (watched 30 minutes on my TV and then doubled checked each title until I found the right one) and, for me, it was the first title.
Source file name: 00006.mpls
Duration: 1:32:20
Chapters count: 16
Segment count: 21
Segment map: 513,514,519,505,517,520,515,518,512,516,506,501,510,79,508,507,511,503,502,509,504
File name: WILD_CARD_t00.mkv
Hopefully this helps someone else out. Take care.
dark_slayer
NEO Dan wrote:Name: WILD CARD
Duration: 1:32:20
Chapters count: 16
Segment count: 21
nivick wrote:I can start this on off hopefully with 507 for the disc I have...
Thanks both, I must of had the same disc
dashocker
Post by dashocker »
Any confirmation on correct MPLS?
johng
Post by johng »
Can you elaborate on what the issue is with installing PowerDVD and using MakeMKV? It seems that others on this forum have done this and haven't reported any problems???
johng
Post by johng »
This technique only requires PowerDVD and has nothing to do with AnyDVDHD.
Woodstock wrote:The video I watched did not require AnyDVD, just "something" that can play BD disks directly, and PowerDVD is probably the most popular. Free versions of that come with most retail packaged BD drives. I don't use it because it installs drivers that interfere with MakeMKV.
Pulled out the copy of PowerDVD 10 I have, and installed it. It's coming back out, because I now remember WHY I removed it in the first place. PowerDVD insists on setting region codes on my drives, which do not currently have them, before it will use them to play content. Not acceptable for me. Even though MakeMKV can work around the region coding, I'd rather not have it set anyway.
