Does anyone else having problem with backing up "The Theory of Everything"? It would go to about 80% then slow down to 0.00x. Then Error message.
Please help.
Thanks in advance
Re: The Theory of Everything
Might help to know what the error message IS...
See the FAQ in my signature.
CaptBender
I have a problem just opening the disc, it does appear to be undamaged. Attached is the log. Nevermind, it won't let me attach the log, maybe because I'm a new member, well, pasted below.
MakeMKV v1.9.1 win(x64-release) started
Debug logging enabled, log will be saved as C:\Users\CaptBender/MakeMKV_log.txt
DEBUG: Code 100864261 at 5C"5|V)_l/F7(vh[%%:213132100
DEBUG: Code 100864261 at 5C"5|V)_l/F7(vh[%%:29393930
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading 'BD-ROM ATAPI iHOS104 WL0B' at offset '655360'
LIBMKV_TRACE: UDF mount: disc not properly formatted or damaged disc (rootdirs failing)
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading 'BD-ROM ATAPI iHOS104 WL0B' at offset '32768'
DEBUG: Code 0 at }tdh#~-A6N> /_$_/_=:213129777
Debug log started at Mon Mar 23 03:52:03 2015 , written by MakeMKV v1.9.1 win(x64-release)
001005:0000 MakeMKV v1.9.1 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\CaptBender/MakeMKV_log.txt
001003:0020 DEBUG: Code 2 at `|<T"dbf@uC2lNEo:213137827
001003:0020 DEBUG: Code 100864261 at 5C"5|V)_l/F7(vh[%%:213132100
001003:0020 DEBUG: Code 100864261 at 5C"5|V)_l/F7(vh[%%:29393930
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading 'BD-ROM ATAPI iHOS104 WL0B' at offset '655360'
001002:0020 LIBMKV_TRACE: UDF mount: disc not properly formatted or damaged disc (rootdirs failing)
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading 'BD-ROM ATAPI iHOS104 WL0B' at offset '32768'
001003:0020 DEBUG: Code 0 at }tdh#~-A6N> /_$_/_=:213129777
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading 'BD-ROM ATAPI iHOS104 WL0B' at offset '18666158080'
Application exited at Mon Mar 23 03:59:22 2015
The operating system is having issues with the disk, too:
Even when Windows got passed that, it found read errors later on. The disk has issues, but... there is one thing you may not have tried... Have you reset (as in powered off or hit the reset button) your computer?
Sounds stupid, but sometimes hardware will get in a state that Windows can't deal with, and a reset is required. Reboots do not reset the hardware itself, so problems can persist when you just restart without sending the reset signal throughout the motherboard.
