Enlarge Processing Time @ "The Prodigy - Live - WoF"-Bluray
DerDicke1975
#1 Post by DerDicke1975 » Sun Mar 22, 2015 10:17 am
Hi Guys,
I did the first time problems with MakeMKV.
I would like to Bluray "The Prodigy - Worlds On Fire (Live)" EAN: 711297880458 convert a rip and then for a long ride for viewing on mienem tablet.
If I grab the Bluray in my drive this is recognized by MakeMKV, but the Bluray is not opened.
I can not get through to Dics structure to select the each title for converting ie. So far I have never had such a problem with MakeMKV.
What can be the problem? Is there a solution in this case?
I thank you for the answers.
Re: Enlarge Processing Time @ "The Prodigy - Live - WoF"-Blu
#2 Post by Woodstock » Sun Mar 22, 2015 5:14 pm
No need to use colored text.
Follow the FAQ linked in my signature to give us some information to work with on your issue - what you've posted so far isn't helpful.
Also, for viewing on a tablet, you are probably going to need to process the MKV file afterward, to make it compatible with the tablet's player software.
