Win explorer crashes when I navigate to folder with MKVs?!?
Have Win7x64 and have had no problems with other versions of MakeMkv. I can rip MadMen S1D2 without error but when I navigate to the folder that has the MKVs windows explorer crashes. I tried it from a networked pc (also Win7) and it crashes as well.
This never happened before
Re: Win explorer crashes when I navigate to folder with MKVs?!?
**Update
just tried it for another Blu-ray and same thing. I had to use a laptop with XP to connect over the network to even be able to delete the folder. I can still navigate to folders with MKVs created with an older version of MakeMKV with no issue.
Two different discs on two different win7 machines same exact problem with version 12.
I'm totally stumped
I'm totally stumped
- Contact:
What MKV-related software do you have installed? Haali, CCCP, Divx MKV preview or anything like that?
Yes I had the full *free* Divx product on which I assume included MKV Preview. I suspected Divx could've had something to do with so I uninstalled it but the problem still remains.
It is a weird issue. It happens to me too. At first I thought it was divx because it actually showed in the windows explorer error that some divx.dll was involved. I uninstalled it and the problem persisted. When I did a completely fresh install of windows 7 on my laptop, and copied the files back over, I could not replicate the problem (while windows didn't know what to do with mkv). I installed divx again and it started happening. I read online somewhere that Haali can cause this as well. The really weird thing is that you can't select the files by browsing to them (since windows explorer keeps crashing whenever you open the containing folder) but you can select them through another program's browser. For instancem, if I opened up MakeMKV and clicked add source or something and started browsing for a source from within MakeMKV, explorer will not crash. I can right click a file from within that window and it will even play! You can even copy and paste them that way. WTF? Also, one mistake I made was copying a mkv file to the desktop because I thought it was the "problem mkv." It indeed was a problem because windows explorer would endlessly crash and restart. Even if I restarted my computer it would start crashing and restarting (windows explorer that is) again. Any further info on this would be very helpful and interesting...
glad to see i'm not the only one. I'v installed the latest version and it's the same problem.
What 'other' program are you using to select and play them?
I've been using divx. I wonder if this problem has been posted on their forums.
The problem is no the software it's the fact that you've got movie clip thumbnails turned on for MKVs and maybe other movie formats as well. This is well know to crash explorer for any number of reasons (known and unkown a like).
Try this, Turn your folders to detailed view or any other view that doesn't give you a preview of the movie, or you could try just turning off all previews & summary info by running this in the run command (at your own risk (just civering my ass here ))
and to turn them back on with
if by running you still have the issue I Would try uninstalling and reinstalling your codec pack (my person choice is CCCP) and making sure not to enable thumbnail or previews during the codex install.
regsvr32 /u shmedia.dll
regsvr32 shmedia.dll
It appears that 1.5.1 doesnt have the problem...this is of course if something else hasnt changed on my pc.
The one interesting thing already pointed out is if I try to open the folder in an application...could be anything like notepad...and view the files ...in detail in thumbnail doesnt matter...nothing crashes and I can move, delete, etc...
so thats another stop gap solution if the problem re-appears
@factory 15
Your last post here is confusing, so please clarify:
Are you saying that now that you are using MakeMKV v.1.5.1, your "crashing" problem has disappeared?
correct. for the "one" test i did the problem has not re-occured. But i failed to mention the mkv is not even playable on my pc- once again i didnt even test playing it when i wrote my last response- so in reality ....yeah... this is probably not a good test.
- Contact:
1.5.1 had a change for producing "more compatible MKV". Glad it worked out.
Same thing is happening to me. Latest build (1.5.2) and ive tried 2 different codec packs (divx and Haali). Im running W7. Previous MKV's made with DVD's on old version work fine.
Had the same issue. I did a fresh reinstall of Win 7 and using CCCP and Windows Media Player...no issues. The thing that changed for me was associating the .mkv to Windows Media Player vs. VLC. My movie collection is mostly Bluray and I find VLC is lagging when it comes to Bluray support.
Same thing happens to me with 1.5.2. Using Win7 x64 and recently uninstalled DivX, now only have ffdshow installed. Gonna try installing the new DivX Play 8.0. Only crashes when opening folder where MakeMKV just output the MKVs created. Only solution I have is to log off or restart the system. Hoping a fix could be found soon and released in 1.5.3 because this is quite annoying!
