House - Video artefeact
cogitare
#1 Post by cogitare » Sat Mar 07, 2015 3:58 am
I have purchased the BR Complete House MD box set. When I run it through MakeMKV it completes successfully but when played a band of video artefact appears which runs roughly across the middle in a variety of colours as a band. This occurs from 1-3 times and lasts around 2 seconds. Playback continues otherwise unaffected. I tried a different BR unit, same effect.
Re: House - Video artefeact
#2 Post by Woodstock » Sat Mar 07, 2015 3:42 pm
Was there anything in the log of the rip? What you describe could be an example of a BD+ interpretation failure, and there would usually be something mentioned in the log.
See the FAQ in my signature, and retry the rip with debug logging enabled.
cogitare
#3 Post by cogitare » Mon Mar 09, 2015 1:33 am
I have sent txt file to the support email address, no obvious issues to me, but I have no real idea. Plays fine on PS3 btw.
cogitare
#4 Post by cogitare » Tue Mar 10, 2015 11:53 pm
So any idea why this is happening?
cogitare
#5 Post by cogitare » Thu Mar 12, 2015 3:55 am
Well I guess this must have been closed - or there is no answer
#6 Post by Woodstock » Thu Mar 12, 2015 5:14 pm
MakeMKV doesn't have paid support people or "open/closed" tickets. And since Mike isn't here every day, it can be a few days to get answers when things are sufficiently weird. And, since I haven't seen the log, I can't tell what level of weird we're talking about here. :)
cogitare
#7 Post by cogitare » Fri Mar 20, 2015 1:26 am
Test dump sent several days ago hope it helps.
cogitare
#8 Post by cogitare » Tue Apr 14, 2015 12:51 pm
OK so more on this issue. I ripped House MD Bluray. Once or twice on each episode a video artefact appears. I ripped the disc originally with Makemkv. Played back in Plex gives the artefact, VLC plays perfectly. Ripped again with another software to an iso file. Makemkv used again on iso file. Same result. Artefact appears at exactly the same time mark.
So is it Plex or Makemkv or both?
I tried to attach a photo to show the artefact but get an error "Sorry, the board attachment quota has been reached."
Any further ideas?
#9 Post by Woodstock » Tue Apr 14, 2015 5:27 pm
Is Plex transcoding the video to your TV or device? VLC would not have to, but a lot of devices have requirements that Plex tries to cater to, and the transcoding may be where the glitch is coming from. Since the raw file is the same, the error would be the same when the file is played.
cogitare
#10 Post by cogitare » Wed Apr 15, 2015 7:50 am
Hmm I'll check in the Plex settings to see if its doing anything or passthrough. The glitch seems to occur at around the same time point almost 14mins, and in multiples of 14, for e.g. the second occurred at 42mins. The effect occurred at around the 14 min mark on the next episode also. It last about 1-2 s. If you want to see the image i have posted on the Plex forum at https://forums.plex.tv/index.php/topic/ ... -artefact/.
This effect was also found on Looper when I watched it, but other blurays have generally seemed ok. Never seen on DVD.
cogitare
#11 Post by cogitare » Thu Apr 16, 2015 4:30 am
OK problem occurs when Plex Video hardware acceleration is turned on. Also seems to occur with scene changes.
Thanks for help
makememe
#12 Post by makememe » Thu Apr 16, 2015 12:28 pm
where is the plex video acceleration setting? what version do you have because I have yet to find it. what do you mean by played back in plex? are you testing from the server machine or an app or a browser on another machine? if browser, which one?
#13 Post by Woodstock » Thu Apr 16, 2015 3:51 pm
While I do not use Plex on my system, I recall that the hardware acceleration option is ONLY displayed/available if your server supports it. If you don't have the hardware, you won't even be asked.
makememe
#14 Post by makememe » Thu Apr 16, 2015 8:01 pm
I do not mean to derail this thread, but I am curious about using the gpu. I have yet to find anything by plex referring to ha and the requirements etc. I see others mentioning how they configure it, but I do not have the option. This thread has opened up a mystery for my ht solution.
there are suggestions at plex regarding ha and turning it off, for some issues, and that concurs with what cogitare observed.
thanks woodstock.
cogitare
#15 Post by cogitare » Wed Apr 22, 2015 2:39 pm
Go to PHT (current non plex pass version )preferences, video playback, its an option. Not on server app. I leave it off and video plays fine, weird tho.
