Hunger Games Mockingjay Part 1 - rental via RB
1BadRipper
Re: Hunger Games Mockingjay Part 1 - rental via RB
Post by 1BadRipper »
Anybody having Lip Sync issues with their rips?
Mine starts out normal but about the halfway point the sync is more noticeable and by the end of the movie its way off.
Audio sync issues "mostly" point at the player. Not entirely - there can be issues with the file that cause it.
One of the Samsung smart tvs here gets badly out of sync on "All of Me" (a DVD rip, converted to MP4), but everything else plays the file just fine. But I have had to re-rip the occasional disk because the file was damaged. But I don't remember having to do that in a long time.
Minesh
Post by Minesh »
1BadRipper wrote:Anybody having Lip Sync issues with their rips?
I have same problem. I am getting audio sync problem at the halfway.
cptwinder
Post by cptwinder »
How does one figure out the correct file to save? For DVDs I could open them in DVDPlayer and look at the title number.
I use a Mac if that makes a difference.
randomthom
Post by randomthom »
Just ripped mockingjay part 1 from the standard retail blu-ray + digital.
All appears to be working fine.
Source file name: 00871.mpls
Duration: 2:02:50
Chapters count: 16
Segment count: 20
Segment map: 512,520,507,504,503,514,506,516,501,509,515,517,502,505,513,518,519,510,511,508
File name: The_Hunger_Games_Mockingjay_-_Part_1_t470.mkv
sveighten
Post by sveighten »
ellhef wrote:
strobelighthos wrote:Does anyone know what mpls is correct for the Netflix bluray version?
I see the same information as above for 00697.mpls on this version, including segment map. Suspect it's the same...
I thought the list of chapters was sorted, thus I search through the list of 600 by scrolling and clicking, then found 697 missing (not between 695 and 699).
Turns out the list is not sorted, and once found 697 had the same list of segments as people mentioned as being successful.
