Has Yosemite 10.10.2 broken MakeMKV?
Captain Composite
After updating OSX Yosemite to 10.10.2, Make MKV no longer works, even on blu-ray discs I've ripped previously.
I Get the error messages:
Error 'Scsi error - MEDIUM ERROR:UNRECOVERED READ ERROR' occurred while issuing SCSI command AD010..080002400 to device 'IoKit:IOBDServices:3ce0a4bc97db5fe4:TSSTcorp BDDVDW SE-506BB TS00'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0A296C8C33E970F77397347713069C99A63 to device 'IoKit:IOBDServices:3ce0a4bc97db5fe4:TSSTcorp BDDVDW SE-506BB TS00'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0B5400AFE128CDF241A96FAED31F9306D40 to device 'IoKit:IOBDServices:3ce0a4bc97db5fe4:TSSTcorp BDDVDW SE-506BB TS00'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'IoKit:IOBDServices:3ce0a4bc97db5fe4:TSSTcorp BDDVDW SE-506BB TS00'
Highest AACS version is v47 , MKB saved as /Users/xxxxx/.MakeMKV/MKB_v47_THE_XXXXXXXXXX_S2_DISC_1.tgz
It's a Samsung BD-R/RE drive.
Does Make MKV need to be updated to cope with 10.10.2?
Re: Has Yosemite 10.10.2 broken MakeMKV?
It looks like Yosemite is taking over control of the BD AACS key exchange, preventing MakeMKV from doing it. Each version of OSX gets more particular than the previous about what programs are allowed to access "super user" mode.
Unless you're still running an old version of MakeMKV that doesn't include support for AACSv47... 1.8.11 was the first to support v47, but there have been 5 versions released since that, with 1.9.1 supporting AACSv51.
Please send the full log to support@makemkv.com
Pale Rider
Sure looks like this could be a Yosemite problem. I have been running 10.10.2 and now 10.10.3. Ever since I stepped up to 10.10.2, my External Samsung SE-506 simply will not load up any BR disc under MakeMKV 1.91, including those I have successfully ripped under previous versions of OS X, with this same iMac and external drive combo [plugged directly into iMac, no hub]. After spinning for several seconds, blue light flashing, it all craps out with this message:
Here is the debug log.txt today from a disc I successfully ripped last month:
Manufacturer: TSSTcorp
Product: BDDVDW SE-506CB
Revision: TS00
Serial number: S1666YMF50009F
Bus encryption flags: 1F
Highest AACS version: 50
No disc insertedCode: Select all
Debug log started at Mon Feb 9 00:10:00 2015 , written by MakeMKV v1.9.1 darwin(x86-release)
001005:0000 MakeMKV v1.9.1 darwin(x86-release) started
001004:0000 Debug logging enabled, log will be saved as /Users/~/MakeMKV_log.txt
002010:0000 Optical drive "BD-RE TSSTcorp BDDVDW SE-506CB TS00d" opened in OS access mode.
001003:0020 DEBUG: Code 0 at CWNe.K'>B [Jt+JG><.M0\n)}:121263153
DEBUG: Code 0 at +%ipU{2e&m~4);#?O$F#Q JR_:29394160-
Can you please share the log file from a "no disc inserted" session? Any errors there?
Pale Rider
I tried but got this error message:
"Sorry, the board attachment quota has been reached." So, here is the excerpt, apparently with no errors:
Debug log started at Thu Mar 5 15:59:34 2015 , written by MakeMKV v1.9.1 darwin(x86-release)
001004:0000 Debug logging enabled, log will be saved as /Users/****/MakeMKV_log.txt
OneFastSkater
Has anyone solved this?
I'm running OS X 10.10.2 and I have lost the ability to rip DVD's and Blu-Ray's. When I insert a disk the external drive spins the disk and then after a minute or two ejects the disk.
This is the drive I hails as:
HL-DT-ST BD-RE BE14NU40:
Firmware Revision: 1.00
Interconnect: USB
Burn Support: Yes (Generic Drive Support)
Profile Path: None
Cache: 4064 KB
Reads DVD: Yes
CD-Write: -R, -RW
DVD-Write: -R, -R DL, -RAM, -RW, +R, +R DL, +RW
BD-Write: -R, -RE
Write Strategies: CD-TAO, CD-SAO, CD-Raw, DVD-DAO
Media: To show the available burn speeds, insert a disc and choose File > Refresh Information
This is the contents of the Debug Log:
Debug log started at Wed Mar 4 23:26:55 2015 , written by MakeMKV v1.9.1 darwin(x86-release)
001004:0000 Debug logging enabled, log will be saved as /Users/onefastskater/MakeMKV_log.txt
002010:0000 Optical drive "BD-RE HL-DT-ST BD-RE BE14NU40 1.00d" opened in OS access mode.
Application exited at Thu Mar 5 13:24:14 2015
I read more posts here and tried to rip using the command line and got the following:
tests-MacBook-Pro:~ onefastskater$ cd /Applications/MakeMKV.app//Contents/MacOS/
tests-MacBook-Pro:MacOS onefastskater$ ./makemkvcon info disc:1
DEBUG: Code 1 at @p-LEyK`!o{u:fud /[RY:213132951
Total 0 titles
What's going on?
Interconnect: USB
Profile Path: None
Cache: 4064 KB
Reads DVD: Yes
CD-Write: -R, -RW
BD-Write: -R, -RE
Total 0 titles
What's going on?
TEG24601
I'm running into the same issue. I have a Buffalo brxl-pc6u2, and it worked great since I got it in the fall, then I wasn't really using it for a few months, then picked up the Star Trek: TNG BDs and they won't even load. Any CD or DVD loads without issue. Any idea what can be done?
Describe "won't even load" better - OS X says no disk, or what?
OneFastSkater
No error from OS X however I did find the following in the console ...
Mar 14 07:45:40 tests-MacBook-Pro com.apple.xpc.launchd[1] (com.apple.imfoundation.IMRemoteURLConnectionAgent): The _DirtyJetsamMemoryLimit key is not available on this platform.
Mar 14 07:48:52 tests-MacBook-Pro.local Console[1282]: Failed to connect (_consoleX) outlet from (NSApplication) to (ConsoleX): missing setter or instance variable
Mar 14 07:49:07 tests-MacBook-Pro.local makemkv[1289]: WARNING: The Gestalt selector gestaltSystemVersion is returning 10.9.2 instead of 10.10.2. Use NSProcessInfo's operatingSystemVersion property to get correct system version number.
Call location:
Mar 14 07:49:07 tests-MacBook-Pro.local makemkv[1289]: 0 CarbonCore 0x91c767c7 ___Gestalt_SystemVersion_block_invoke + 135
Mar 14 07:49:07 tests-MacBook-Pro.local makemkv[1289]: 1 libdispatch.dylib 0x9aadf0b5 dispatch_once_f + 251
Mar 14 07:49:07 tests-MacBook-Pro.local makemkv[1289]: 2 libdispatch.dylib 0x9aae00d8 dispatch_once + 31
Mar 14 07:49:07 tests-MacBook-Pro.local makemkv[1289]: 3 CarbonCore 0x91c08e88 _Gestalt_SystemVersion + 1050
Mar 14 07:49:07 tests-MacBook-Pro.local makemkv[1289]: 4 CarbonCore 0x91c08a39 Gestalt + 150
Mar 14 07:49:07 tests-MacBook-Pro.local makemkv[1289]: 5 libmqt.dylib 0x06314ff0 _Z6qDebugPKcz + 2144
Mar 14 07:49:07 tests-MacBook-Pro.local makemkv[1289]: 6 ??? 0x8fe250b3 0x0 + 2413973683
Mar 14 07:50:21 tests-MacBook-Pro com.apple.xpc.launchd[1] (com.apple.imfoundation.IMRemoteURLConnectionAgent): The _DirtyJetsamMemoryLimit key is not available on this platform.
Mar 14 07:50:32 tests-MacBook-Pro.local discoveryd[53]: Basic DNSResolver UDNSServer::ProcessEvent unknown event type: 7!
Mar 14 07:50:32 tests-MacBook-Pro.local iTunes[433]: Entered:_AMMuxedDeviceDisconnected, mux-device:67
Mar 14 07:50:32 tests-MacBook-Pro.local iTunes[433]: Entered:__thr_AMMuxedDeviceDisconnected, mux-device:67
Mar 14 07:50:32 tests-MacBook-Pro.local iTunes[433]: tid:21beb - Mux ID not found in mapping dictionary
Mar 14 07:50:32 tests-MacBook-Pro.local iTunes[433]: tid:21beb - Can't handle disconnect with invalid ecid
Mar 14 07:50:38 tests-MacBook-Pro.local com.apple.usbmuxd[57]: LOCKDOWN_V2_BONJOUR_SERVICE_NAME is _apple-mobdev2._tcp,9437080a
Mar 14 07:50:38 tests-MacBook-Pro.local com.apple.usbmuxd[57]: _SendAttachNotification Device 10:40:f3:b7:8e:97@fe80::1240:f3ff:feb7:8e97._apple-mobdev2._tcp.local. has already appeared on interface 4. Suppressing duplicate attach notification.
Mar 14 07:56:28 tests-MacBook-Pro.local mds[34]: (DiskStore.Normal:2376) b001 1.000043
Mar 14 07:57:27 tests-MacBook-Pro.local makemkv[1298]: WARNING: The Gestalt selector gestaltSystemVersion is returning 10.9.2 instead of 10.10.2. Use NSProcessInfo's operatingSystemVersion property to get correct system version number.
Call location:
Mar 14 07:57:27 tests-MacBook-Pro.local makemkv[1298]: 0 CarbonCore 0x91c767c7 ___Gestalt_SystemVersion_block_invoke + 135
Mar 14 07:57:27 tests-MacBook-Pro.local makemkv[1298]: 1 libdispatch.dylib 0x9aadf0b5 dispatch_once_f + 251
Mar 14 07:57:27 tests-MacBook-Pro.local makemkv[1298]: 2 libdispatch.dylib 0x9aae00d8 dispatch_once + 31
Mar 14 07:57:27 tests-MacBook-Pro.local makemkv[1298]: 3 CarbonCore 0x91c08e88 _Gestalt_SystemVersion + 1050
Mar 14 07:57:27 tests-MacBook-Pro.local makemkv[1298]: 4 CarbonCore 0x91c08a39 Gestalt + 150
Mar 14 07:57:27 tests-MacBook-Pro.local makemkv[1298]: 5 libmqt.dylib 0x06314ff0 _Z6qDebugPKcz + 2144
Mar 14 07:57:27 tests-MacBook-Pro.local makemkv[1298]: 6 ??? 0x8ff020b3 0x0 + 2414878899
Mar 14 07:57:30 tests-MacBook-Pro com.apple.xpc.launchd[1] (com.apple.quicklook[1301]): Endpoint has been activated through legacy launch(3) APIs. Please switch to XPC or bootstrap_check_in(): com.apple.quicklook
Mar 14 07:57:32 tests-MacBook-Pro.local QuickLookSatellite[1303]: CGSConnectionByID: 0 is not a valid connection ID.
Mar 14 07:57:32 tests-MacBook-Pro.local QuickLookSatellite[1303]: Invalid Connection ID 0
Call location:
Call location:
OneFastSkater
Behavior seen:
1. MKV not running - place a DVD in the drive.
2. Expect Apple DVD player to complain that this is not an apple disk drive. This does not happen. Drive attempts to access the disk and finally ejects if.
3. MKV running - place a disk in the drive (DVD or BluRay).
4. Drive attempts to access disk for about 30-45 seconds and eventually ejects the disk.
As I have posted no debug information in the makemkv log.
The console information I posted was the result of these two attempts.
OneFastSkater
Tried a few more things to debug ...
1. Used VMware fusion to boot up windows and still unable to read/burn disks.
2. Connected the HL-DT-ST BD-RE BE14NU40 to an older MacBook running OS x 10.8. Still unable to read/burn drives.
I'm leaning to the firmware or a drive failure at the moment. LG site only has PC .exe firmware up grader. No support for OS X, device drivers and/or firmware.
Apple explicitly does not support BluRay.
Not sure what to try next. I don't have any PC's lying around.
Pale Rider
Would be nice to hear something substantive from the team here. I am a paid user, and right now, my only solution is to resort to my Baetis server to back up my disks. That is tolerable, but not optimal, for this user.
OneFastSkater
Carbon Core Deprecations
Carbon Core, a subframework of the Core Services umbrella framework, contains the programming interfaces of many legacy Carbon managers, in addition to various utilities. In OS X v10.8, most of these interfaces are deprecated.
If your app uses APIs in the Carbon Core framework, it’s recommended that you investigate ways to update your code. This document lists the Carbon Core header files that are deprecated in OS X v10.8 and summarizes some of the alternative APIs you can use.
Note: If you use QuickTime in your app you should investigate transitioning to APIs in the AV Foundation, Core Media, and Video Toolbox frameworks instead. If you must use QuickTime APIs, you might have to continue using some of the Carbon managers, such as Component Manager and Alias Manager, and some of the data types and error codes defined in deprecated header files, such as MacErrors.h and MacMemory.h.
Lovely Rita
Updated to Yosemite, myself, this past weekend and I'm NOT experiencing this issue.
