Looks like there is an issue with the above Region 2 film being ripped.
Extracts about 3GB of 4GB even though the progress bar has gotten to the end and then report there was a fatal error and quits. The resultant file only contains the AC3 audio according to MediaInfo and is not playable in VLC or Plex or Quicktime. Does the same thing whether using Direct Access or OS Access.
Attached is the Diagnostic Report from my mac if this is any help.
G1ngerninja
Resident Evil Apocalypse
- Contact:
Re: Resident Evil Apocalypse
Looks like a corrupted data on disc. Please try the following:
- quit MakeMKV
- Naviaget to your home folder, there should be a hidden folder called .MakeMKV, go to this folder
- in this folder you will see a file settings.conf , open it with a text editor
- add a line to this file right after any other setting line:
Save the file, try again and see if it changes anything.
- quit MakeMKV
fs_ForceIsoForUDF102 = "0"-
g1ngerninja
Mike,
It failed again and I have another disk that has done the same thing X-Men!
I have also tried this with 2 different drives, my Samsung SH-B083 Bluray and Sony DW-D150A DVD-ROM that came with the mac pro both do exactly the same thing.
I attach the log file for analysis.
Any further suggestions.
g1ngerninja
g1ngerninja
g1ngerninja
Mike,
Just to be sure I have run this disk on a compiled version under Mandriva 2009 and the same problem occurs. However the debug messages are different which I have attached. Also the Linux version doesn't jush crash it just says "Copy Complete. 0 Titles saved, 1 failed." and returns to the title selection screen.
g1ngerninja
g1ngerninja
- Contact:
Launch the program, go to preferences, on DVD tab change "structure protection method" from Auto to CellTrim and try again. Don't forget to change that setting back to Auto, once you're done with the disc. Please let me know if it worked. With that setting you may get only main movie and no "extra" features, that's normal.g1ngerninja wrote:Mike,
g1ngerninja
Mike,
I tried what you suggested only it quit whilst trying to read the dvd structure issuing this log :-
Debug log started at Fri Mar 19 19:11:59 2010 , written by MakeMKV v1.5.1 beta darwin(x86-release)
001005:0000 MakeMKV v1.5.1 beta darwin(x86-release) started
001004:0000 Debug logging enabled, log will be saved as /Users/cra/MakeMKV_log.txt
003002:0000 Calculated BUP offset does not match one in IFO header.
I also tried the other option CellWalk but that died just like before.
g1ngerninja
g1ngerninja
Have the same problem / error with Resident Evil Afterlife (German 2D Blu-ray) and MakeMKV 1.7.5.
