VLC crashes when trying to play ripped Blu-ray
hamburglar
#1 Post by hamburglar » Sat Mar 14, 2015 9:42 pm
I am trying to rip Part 2 of The Lord of the Rings: The Two Towers Extended Edition and it appears to rip okay and MakeMKV doesn't give me any error messages. When I double-click the .mkv file to open it in VLC, the program crashes immediately. It allows me to send an error report to VLC, but I don't know how I can access the error report. I am able to rip and play other Blu-ray discs just fine, just not this one. I had previously been able to rip it in the past, so I don't know what's wrong.
Re: VLC crashes when trying to play ripped Blu-ray
#2 Post by Woodstock » Sat Mar 14, 2015 10:23 pm
Which version of VLC?
I'm about to abandon 2.2.0, because it has issues playing some MKV files that work just fine in 2.1.5. Had to do the same thing when 2.0.x came out, because things that played in the 1.x series blew up 2.0. It was 2.0.3 before it became stable again.
hamburglar
#3 Post by hamburglar » Sat Mar 14, 2015 11:00 pm
I'm using 2.2.0 right now. Should I downgrade and see if it works? Since the movie is split into two discs, I tried using mkvmerge to make Part 1 and Part 2 into one .mkv file and mkvmerge gave me an error, so it seems to be more than just VLC.
#4 Post by Woodstock » Sun Mar 15, 2015 12:26 am
You can have multiple versions of VLC installed, so long as they're in different directories, so I'd start with that. You can also have multiple copies of MakeMKV installed, with the same restriction, so checking an older version to see if it's a change in MakeMKV is also possible.
hamburglar
#5 Post by hamburglar » Tue Mar 17, 2015 1:46 am
I found out I have the same problem with the second disc of The Return of the King. Where can I download previous versions of MakeMKV?
#6 Post by Woodstock » Tue Mar 17, 2015 3:20 pm
/download/old/
hamburglar
#7 Post by hamburglar » Thu Mar 19, 2015 7:42 pm
I'm not a paid subscriber, so it wouldn't let me use the older versions. I borrowed my friend's registration key just to test it and it didn't work on 1.9.0 or 1.8.9 so I don't know where to go from here.
#8 Post by Woodstock » Thu Mar 19, 2015 11:25 pm
With older versions, you need to enter the updated beta key that is posted in the announcements section, under "MakeMKV is free during Beta".
hamburglar
#9 Post by hamburglar » Fri Mar 20, 2015 5:02 pm
Woodstock wrote:With older versions, you need to enter the updated beta key that is posted in the announcements section, under "MakeMKV is free during Beta".
Okay, thank you for this. However, I'm still having the problem.
A somewhat new development, I was able to convert a chapter of the unplayable file to an .mp4 file with Handbrake and it was playable. I tested this with both the first chapter and second chapter.
