The Hunger Games Mockingjay Part 1 -correct playlist (mpls)
ppoulos
Has anyone figured out what the correct playlist (mpls file) is for the European release of The Hunger Games Mockingjay Part 1? They are making the discs more complicated, now with much more fake playlists all with the same run time (except for playlist 000420.mpls which is 1 minute longer).
dvu0704
Re: The Hunger Games Mockingjay Part 1 -correct playlist (m
Correct playlist is = 00553.mpls
ppoulos
Thanks... I'll try that playlist.dvu0704 wrote:Correct playlist is = 00553.mpls
bk7777
It is not the same on US rental version
mothball
Title information
Name: The Hunger Games: Mockingjay - Part 1 (English)
Source file name: 00553.mpls
Duration: 2:02:50
Chapters count: 16
Segment count: 20
Segment map: 503,520,516,510,511,506,507,514,518,509,519,517,501,505,502,512,515,504,513,508
File name: The_Hunger_Games_Mockingjay_-_Part_1_t296.mkv
there are other threads that seems to indicate that there are alternate correct MPLS files depending on where you acquired the disc - mine was costco 2 disc combo verified playlist using powerdvd and process monitor method
Duration: 2:02:50
Chapters count: 16
Segment count: 20
mrjones45
This is the first time I have dealt with this type of Blu-ray. I've read as much as I can find and I understand the playlist and segment maps, but I don't know how to extract only those files. Any help?
You unselect all the other... Right-click on the title list, select "Unselect All", and then find the one you want, and check it.
jonesthegas
I have the UK release. Using powerdvd and process monitor it seems to be 871 with segment order
512,520,507,504,503,514,506,516,501,509,515,517,502,505,513,518,519,510,511,508
WhiteHawk77
This is such pointless nonsense by Lionsgate, again with this, I have the UK single release and there is no 871 playlist.
makememe
Yes, it is pointless especially if you search youtube for bluray playlist obfuscation. That approach has been pointed out here several times--and elsewhere, so take a look and never have to ask again.WhiteHawk77 wrote:This is such pointless nonsense by Lionsgate, again with this, I have the UK single release and there is no 871 playlist.
It requires a bluray player, but that is a small price for not waiting to have someone present the correct playlist for your disk.
