On some newer BD disks e.g. The Hunger Games: Mockingjay - Part 1, I get a very large amount of titles selected when the disk is analysed. I normally only want the first one, but to do that I need to de-select (uncheck) all the others. All of the titles seem to be of the same size gbyte wise.
Why is this happening and what does it mean? It seems to be related to mpls's.
Is there any way of forcing makemkv to just select the actual movie?
Is there any way of easily unchecking all the titles so I can then check the one I want?
TIA
Barry Gordon
multiple titles
Re: multiple titles
Mouse pointer on list of titles - click RIGHT button (on Windows) - select "Unselect all" from context menu.
And there are over a dozen threads here this week on "which title do I choose when ripping [insert movie name here]? Read through a few, and you will get some insight on the problem, and maybe find the answers for the particular disk(s) you need to know about.
