SCSI Error - Read of Scrambled Sector without Authentication
SnotMonster
#1 Post by SnotMonster » Fri Feb 05, 2010 8:04 pm
Have encountered my first issue with MakeMKV after successfully ripping around 20 DVDs and Blue-Ray disks. Could anyone advise what could be the cause of the following?
It occurs immediately upon startup of MakeMKV for a DVD that appears to play fine in DVD player. I haven't seen any other reports of this specific SCSI error on this forum.
I'm using the internal DVD drive of my MacBook:
MakeMKV v1.4.12 beta darwin(x86-release) started
Error 'Scsi error - ILLEGAL REQUEST:READ OF SCRAMBLED SECTOR WITHOUT AUTHENTICATION' occured while reading 'DVD+R-DL MATSHITA DVD-R UJ-857E ZF1E' at offset '1048576'
I then tried my external BD Drive - similar issue:
Cannot obtain exclusive access for optical drive "Optiarc BD ROM BC-5500S 1.03" - disc reading will likely fail. You may want to eject and reload the disc while makemkv is running.
Error 'Scsi error - ILLEGAL REQUEST:READ OF SCRAMBLED SECTOR WITHOUT AUTHENTICATION' occured while reading 'BD-ROM Optiarc BD ROM BC-5500S 1.03' at offset '1048576'
As the message suggested I tried to eject and reload the disk with MakeMKV running resulting in the error being reported a 2nd time.
Finally - same issue if I use the BD drive on another Mac
Update:
I have been ripping some DVD box-sets and noticed that I get this error on pretty much all disks. What I had not noticed however until trying to rip these box-sets that the error is really some form of warning - that rips of these disks are still possible and I seem to be able to ignore the error.
Ripman
Re: SCSI Error - Read of Scrambled Sector without Authentica
#2 Post by Ripman » Mon Mar 09, 2015 12:10 pm
I got the "SCSI Error: Read of Scrambled Sector..." message when I was working with the L'Avventura CR DVD. The log is below. This was a brand new DVD, although released more than 10 years ago. I tried the "Pledge" process, as well as two other drives. All of the drives gave the "Scrambled Sector" message. The back cover of the DVD says that it is a "RSDL dual-layer edition," and I am unsure if that is relevant.
In this case, when I inserted the DVD, I got the initial message. I then clicked "Open Disc" and it allowed me to save the title, as indicated in the log. Does this mean that even though I got the "Scrambled Sector" message I ultimately created a "clean" mkv?
Debug log started at Mon Mar 09 01:51:19 2015 , written by MakeMKV v1.9.1 win(x86-release)
001005:0000 MakeMKV v1.9.1 win(x86-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Documents and Settings\Administrator/MakeMKV_log.txt
001003:0020 DEBUG: Code 2 at 5nDMhD0--1"B)Vff:213137827
001003:0020 DEBUG: Code 101019395 at 5DYT{{ch*Ih)+'{E}p:213132100
001003:0020 DEBUG: Code 101019395 at 5DYT{{ch*Ih)+'{E}p:29393930
002003:0000 Error 'Scsi error - ILLEGAL REQUEST:READ OF SCRAMBLED SECTOR WITHOUT AUTHENTICATION' occurred while reading 'DVD+R-DL HL-DT-ST DVDRAM GMA-4082N HV02' at offset '1048576'
003024:1000 Complex multiplex encountered - 36 cells and 17088 VOBUs have to be scanned. This may take some time, please be patient - it can't be avoided.
003028:0000 Title #1 was added (36 cell(s), 2:22:53)
005014:0000 Saving 1 titles into directory C:/50d
005005:0080 1 titles saved
005036:0104 Copy complete. 1 titles saved.
Application exited at Mon Mar 09 02:56:00 2015
edit: Sorry this ended-up on the Mac side, but I wanted to post under the same exact message I was getting. I run Win XP for my MakeMKV env.
#3 Post by Woodstock » Mon Mar 09, 2015 2:58 pm
The error is harmless in this case - when MakeMKV switched to direct access mode, it bypassed the operating system's block against decrypting the data. I get errors like that because my DVD drives have never had a region code selected.
If it had really been a problem, the rip would have failed.
Ripman
#4 Post by Ripman » Tue Mar 10, 2015 2:10 pm
Thanks again Woodstock.
I tried encoding this with HB, and it has problems. I did a post over at HB under the general discussion area. Basically, got frames != expected frames.
Right now, I will try to process the DVD with MakeMKV again, but this time with the TESTDUMP feature enabled. I will post back with the results.
(Mod: This topic should rightly be moved under general discussion as the problem (viz., "scrambled sector") can occur on all of the supported platforms.)
Ripman
#5 Post by Ripman » Tue Mar 10, 2015 3:34 pm
Here is the test dump file:
https://www.dropbox.com/s/wbzzvndfq7ap3 ... 0.tgz?dl=0
Here is the log from the test dump session:
Debug log started at Tue Mar 10 14:05:04 2015 , written by MakeMKV v1.9.1 win(x86-release)
002003:0000 Error 'Scsi error - ILLEGAL REQUEST:READ OF SCRAMBLED SECTOR WITHOUT AUTHENTICATION' occurred while reading 'BD-ROM HL-DT-ST BDDVDRW CP50NS20 1.00' at offset '1048576'
001002:0000 LIBMKV_TRACE: Test dump mode on
Application exited at Tue Mar 10 15:02:53 2015
Please let me know if I should send this info to support as well. Thanks.
#6 Post by mike admin » Wed Mar 11, 2015 3:52 pm
This error is harmless in this context. And yes, if you got an MKV file then everything is fine.
Ripman
#7 Post by Ripman » Tue Apr 14, 2015 1:36 pm
Thanks for your previous response Mike.
This is a really old DVD from 2001, and I am thinking that somehow the DVD ifo is incorrect. The mkv created by MakeMKV for this DVD is invalid; the resultant mkv is longer than the movie duration by about 10s (see chapter times below). During MakeMKV processing startup, the number of cells reported as 36 is incorrect while the displayed total movie duration is short by about 20s (see 1.9.2 log below). I used mmg 7.8.0 to mux the mkv from MakeMKV before feeding to HB, but that did not help.
This DVD has only the movie and a menu; there are no other "extras." I know we can use the so-called "manual mode" now with MakeMKV, and I am wondering how I should do that since there is only title 00. I do not know enough about cell structure, etc. to go any more deeply into "manual mode" without guidance.
Please let me know if there are things I can do to get this DVD processed either using "manual mode" or otherwise. Thanks.
Chapter times comparison.
Sony BDP           mediainfo                                vlc
(DVD)              (mkv from MakeMKV 1.9.2)                (DVD; AnyHD VIDEO_TS)
01 0               00:00:00.000   : en:Chapter 01          01 0
02 2.32            00:02:32.252   : en:Chapter 02          02 1.28
03 4.41            00:04:41.881   : en:Chapter 03          03 3.47
04 6.15            00:06:16.109   : en:Chapter 04          04 5.19
05 10.30           00:10:30.863   : en:Chapter 05          05 9.00
06 15.09           00:15:09.909   : en:Chapter 06          06 14.26
07 18.16           00:18:17.162   : en:Chapter 07          07 18.10
08 20.49 *         00:20:51.083   : en:Chapter 08          08 20.40
09 22.52           00:22:54.272   : en:Chapter 09          09 22.43
10 26.12           00:26:14.005   : en:Chapter 10          10 26.28
11 38.01           00:38:04.215   : en:Chapter 11          11 39.21
12 42.18           00:42:20.538   : en:Chapter 12          12 42.57
13 49.07           00:49:10.047   : en:Chapter 13          13 48.53
14 53.12           00:53:15.325   : en:Chapter 14          14 52.56
15 56.52 *         00:56:56.246   : en:Chapter 15          15 56.13
16 59.55           00:59:59.395   : en:Chapter 16          16 59.15
17 1.02.55         01:02:59.675   : en:Chapter 17          17 1.02.31
18 1.06.11         01:06:15.338   : en:Chapter 18          18 1.05.29
19 1.11.27         01:11:31.287   : en:Chapter 19          19 1.10.49
20 1.15.38 *       01:15:43.171   : en:Chapter 20          20 1.15.16
21 1.17.43         01:17:48.563   : en:Chapter 21          21 1.17.50
22 1.20.22         01:20:27.222   : en:Chapter 22          22 1.20.24
23 1.25.14         01:25:19.481   : en:Chapter 23          23 1.24.53
24 1.27.26         01:27:31.312   : en:Chapter 24          24 1.27.09
25 1.31.38         01:31:43.965   : en:Chapter 25          25 1.31.55
26 1.38.11 *       01:38:17.625   : en:Chapter 26          26 1.38.58
27 1.42.37         01:42:43.824   : en:Chapter 27          27 1.43.54
28 1.47.00         01:47:06.653   : en:Chapter 28          28 1.49.00
29 1.53.17 *       01:53:24.597   : en:Chapter 29          29 1.55.35
30 1.56.59         01:57:06.252   : en:Chapter 30          30 1.59.26
31 2.01.14 *       02:01:22.208   : en:Chapter 31          31 2.03.43
32 2.07.00         02:07:08.354   : en:Chapter 32          32 2.08.51
33 2.13.00         02:13:08.347   : en:Chapter 33          33 2.14.07
34 2.16.07         02:16:16.034   : en:Chapter 34          34 2.16.46
35 2.18.32         02:18:40.345   : en:Chapter 35          35 2.19.01
MakeMKV 1.9.2 log.
Debug log started at Mon Apr 13 02:59:02 2015 , written by MakeMKV v1.9.2 win(x86-release)
001005:0000 MakeMKV v1.9.2 win(x86-release) started
001003:0020 DEBUG: Code 101019395 at h5Skn=GNV(/f53Ux:29401451
001003:0020 DEBUG: Code 101019395 at 5,qlVqt$j{}}@18yLA:213132100
001003:0020 DEBUG: Code 101019395 at 5,qlVqt$j{}}@18yLA:29393930
Application exited at Mon Apr 13 03:59:46 2015
"mediainfo -f " of mkv from MakeMKV 1.9.2.
General
Count                                    : 302
Count of stream of this kind             : 1
Kind of stream                           : General
Stream identifier                        : 0
Unique ID                                : 230096651169898923449404692894085589020
Unique ID                                : 230096651169898923449404692894085589020 (0xAD1B00C87BBD52CEE0BF4C21EE5CA81C)
Count of video streams                   : 1
Count of audio streams                   : 2
Count of text streams                    : 1
Count of menu streams                    : 1
Video_Format_List                        : MPEG Video
Video_Format_WithHint_List               : MPEG Video
Codecs Video                             : MPEG-2 Video
Video_Language_List                      : English
Audio_Format_List                        : AC-3 / AC-3
Audio_Format_WithHint_List               : AC-3 / AC-3
Audio codecs                             : AC3 / AC3
Audio_Language_List                      : English / Italian
Text_Format_List                         : VobSub
Text_Format_WithHint_List                : VobSub
Text codecs                              : VobSub
Text_Language_List                       : English
Complete name                            : L_AVVENTURA_t00.mkv
File name                                : L_AVVENTURA_t00
File extension                           : mkv
Format/Url                               : http://packs.matroska.org/
Format/Extensions usually used           : mkv mk3d mka mks
Commercial name                          : Matroska
Format version                           : Version 2
Codec                                    : Matroska
Codec                                    : Matroska
Codec/Url                                : http://packs.matroska.org/
Codec/Extensions usually used            : mkv mk3d mka mks
File size                                : 7791991308
File size                                : 7.26 GiB
File size                                : 7 GiB
File size                                : 7.3 GiB
File size                                : 7.257 GiB
Duration                                 : 8598080
Duration                                 : 2h 23mn
Duration                                 : 2h 23mn 18s 80ms
Duration                                 : 2h 23mn
Duration                                 : 02:23:18.080
Duration                                 : 02:23:18;02
Duration                                 : 02:23:18.080 (02:23:18;02)
Overall bit rate mode                    : VBR
Overall bit rate                         : 7249983
Overall bit rate                         : 7 250 Kbps
Frame rate                               : 29.970
Frame rate                               : 29.970 fps
Frame count                              : 257684
Stream size                              : 155073165
Stream size                              : 148 MiB (2%)
Stream size                              : 147.9 MiB
Proportion of this stream                : 0.01990
Title                                    : L_AVVENTURA
Movie name                               : L_AVVENTURA
Encoded date                             : UTC 2015-04-13 03:25:37
File creation date                       : UTC 2015-04-13 03:25:37.953
File creation date (local)               : 2015-04-12 23:25:37.953
File last modification date              : UTC 2015-04-13 03:57:53.460
File last modification date (local)      : 2015-04-12 23:57:53.460
Writing application                      : MakeMKV v1.9.2 win(x86-release)
Writing library                          : libmakemkv v1.9.2 (1.3.0/1.4.1) win(x86-release)
Video
Count                                    : 298
Kind of stream                           : Video
StreamOrder                              : 0
Unique ID                                : 1
Format                                   : MPEG Video
Commercial name                          : MPEG-2 Video
Format profile                           : Main@Main
Format settings                          : CustomMatrix / BVOP
Format settings, BVOP                    : Yes
Format settings, Matrix                  : Custom
Format_Settings_Matrix_Data              : 0810101310131616161616161A181A1B1B1B1A1A1A1A1B1B1B1D1D1D2222221D1D1D1B1B1D1D2020222225262523232223262628282830302E2E38383A454553 / 10111112121213131313141414141415151515151516161616161616171717171717171718181819181818191A1A1A1A191B1B1B1B1B1C1C1C1C1E1E1E1F1F21
Format settings, GOP                     : M=3, N=15
Format settings, picture structure       : Frame
Internet media type                      : video/MPV
Codec ID                                 : V_MPEG2
Codec ID/Info                            : MPEG 1 or 2 Video
Codec ID/Url                             : http://ffdshow-tryout.sourceforge.net/
Codec                                    : V_MPEG2
Codec                                    : MPEG-2 Video
Codec/Family                             : MPEG-V
Codec/Info                               : MPEG 1 or 2 Video
Codec/Url                                : http://ffdshow-tryout.sourceforge.net/
Codec profile                            : Main@Main
Codec settings                           : CustomMatrix
Codec settings, Matrix                   : Custom
Duration                                 : 8598065
Duration                                 : 2h 23mn
Duration                                 : 2h 23mn 18s 65ms
Duration                                 : 2h 23mn
Duration                                 : 02:23:18.065
Duration                                 : 02:23:18.065 (02:23:18;02)
Bit rate mode                            : VBR
Bit rate                                 : 6785708
Bit rate                                 : 6 786 Kbps
Maximum bit rate                         : 9800000
Maximum bit rate                         : 9 800 Kbps
Width                                    : 720
Width                                    : 720 pixels
Height                                   : 480
Height                                   : 480 pixels
Pixel aspect ratio                       : 1.185
Display aspect ratio                     : 1.778
Frame rate mode                          : CFR
Frame rate                               : 29.970
Standard                                 : NTSC
Resolution                               : 8
Resolution                               : 8 bits
Colorimetry                              : 4:2:0
Chroma subsampling                       : 4:2:0
Bit depth                                : 8
Bit depth                                : 8 bits
Scan type                                : Interlaced
Scan order                               : TFF
Scan order                               : Top Field First
Interlacement                            : TFF
Interlacement                            : Top Field First
Bits/(Pixel*Frame)                       : 0.655
Delay                                    : 0
Delay                                    : 00:00:00.000
Delay, origin                            : Container
Stream size                              : 7292994943
Stream size                              : 6.79 GiB (94%)
Stream size                              : 7 GiB
Stream size                              : 6.8 GiB
Stream size                              : 6.792 GiB
Proportion of this stream                : 0.93596
Language                                 : en
Language                                 : en
Language                                 : eng
Language                                 : en
Buffer size                              : 229376
intra_dc_precision                       : 10
Audio #1
Count                                    : 267
Count of stream of this kind             : 2
Kind of stream                           : Audio
Stream identifier                        : 1
StreamOrder                              : 1
Unique ID                                : 2
Commercial name                          : AC-3
Mode extension                           : CM (complete main)
Format settings, Endianness              : Big
Codec ID                                 : A_AC3
Codec                                    : AC3
Codec                                    : AC3
Codec/Family                             : AC3
Codec/Info                               : Dolby AC3
Duration                                 : 8598080
Duration                                 : 2h 23mn
Duration                                 : 2h 23mn
Bit rate mode                            : CBR
Bit rate                                 : 160000
Bit rate                                 : 160 Kbps
Channel(s)                               : 1
Channel(s)                               : 1 channel
Channel positions                        : Front: C
Channel positions                        : 1/0/0
ChannelLayout                            : C
Sampling rate                            : 48000
Sampling rate                            : 48.0 KHz
Samples count                            : 412707840
Resolution                               : 16
Resolution                               : 16 bits
Bit depth                                : 16
Bit depth                                : 16 bits
Delay                                    : 0
Delay relative to video                  : 0
Delay relative to video                  : 00:00:00.000
Video0 delay                             : 0
Video0 delay                             : 00:00:00.000
Stream size                              : 171961600
Stream size                              : 164 MiB (2%)
Stream size                              : 164.0 MiB
Proportion of this stream                : 0.02207
Title                                    : Mono
Language                                 : en
Language                                 : en
Language                                 : eng
Language                                 : en
bsid                                     : 8
dialnorm                                 : -31
dialnorm/String                          : -31 dB
compr                                    : -0.28
compr/String                             : -0.28 dB
acmod                                    : 1
lfeon                                    : 0
dialnorm_Average                         : -31
dialnorm_Average/String                  : -31 dB
dialnorm_Minimum                         : -31
dialnorm_Minimum/String                  : -31 dB
dialnorm_Maximum                         : -31
dialnorm_Maximum/String                  : -31 dB
dialnorm_Count                           : 2
compr_Average                            : -0.28
compr_Average/String                     : -0.28 dB
compr_Minimum                            : -0.28
compr_Minimum/String                     : -0.28 dB
compr_Maximum                            : -0.28
compr_Maximum/String                     : -0.28 dB
compr_Count                              : 2
Audio #2
Count                                    : 267
Stream identifier                        : 2
StreamOrder                              : 2
Unique ID                                : 3
Codec ID                                 : A_AC3
Codec                                    : AC3
Codec                                    : AC3
Codec/Family                             : AC3
Duration                                 : 8598080
Duration                                 : 2h 23mn
Duration                                 : 2h 23mn
Bit rate mode                            : CBR
Bit rate                                 : 160000
Bit rate                                 : 160 Kbps
Channel(s)                               : 1
ChannelLayout                            : C
Resolution                               : 16
Bit depth                                : 16
Bit depth                                : 16 bits
Delay                                    : 0
Video0 delay                             : 0
Title                                    : Mono
Language                                 : it
Language                                 : Italian
Language                                 : Italian
Language                                 : it
Language                                 : ita
Language                                 : it
bsid                                     : 8
dialnorm                                 : -31
compr                                    : -0.28
acmod                                    : 1
lfeon                                    : 0
dialnorm_Count                           : 2
compr_Count                              : 2
Text
Count                                    : 210
Kind of stream                           : Text
StreamOrder                              : 3
Unique ID                                : 4
Format                                   : VobSub
Commercial name                          : VobSub
Codec ID                                 : S_VOBSUB
Codec ID/Info                            : The same subtitle format used on DVDs
Codec                                    : S_VOBSUB
Codec                                    : VobSub
Codec/Info                               : The same subtitle format used on DVDs
Language                                 : en
Language                                 : en
Language                                 : eng
Language                                 : en
Menu
Count                                    : 115
Kind of stream                           : Menu
Chapters_Pos_Begin                       : 80
Chapters_Pos_End                         : 115
TCalhau
#8 Post by TCalhau » Sun May 03, 2015 1:57 pm
Hello guys!
I am a user of MakeMKV and recently acquired the MakeMKV as way to help in its development. I love this application! Always use to convert my DVDs to mkv files. I've always had success in my conversions but now I am facing a problem with the DVD 2 (the DVD 1 was converted without problems!) of the ninth Season of Grey's Anatomy (Region 4). Has appeared this message:
MakeMKV v1.9.2 darwin(x86-release) started
Optical drive "DVD+R-DL MATSHITA DVD-R UJ-898 HA07d" opened in OS access mode.
Error 'Scsi error - ILLEGAL REQUEST:READ OF SCRAMBLED SECTOR WITHOUT AUTHENTICATION' occurred while reading 'DVD+R-DL MATSHITA DVD-R UJ-898 HA07' at offset '1048576'
Is this some bug??? How do I solve this problem? I am using version 1.9.2 and Yosemite 10.10.3
#9 Post by Woodstock » Sun May 03, 2015 3:58 pm
OS X is preventing MakeMKV from reading parts of the disk that it needs to read to do the decode. Whether it is doing this because permissions or an actual disk problem, is difficult to tell from the error message, unfortunately. The authentication information MakeMKV tried to send was blocked, so the drive says the access is not authorized.
Ripman
#10 Post by Ripman » Thu Jul 02, 2015 6:28 pm
My previous posts/problems regarding the CR DVD of L'Avventura were solved by removing the VobSub track using mmg. Doing this fixed the "it freezes my lower-end players sometimes" problem.
Removing the VobSub DVD subtitle track also "fixed" these titles:
- Touch of Evil 1997 restored 50th anniversary DVD.
- Seven Days in May TCM DVD.
- Amelie 2002 DVD.
- 3 Days of the Condor DVD.
I muxed in SRT files in all cases, and everything was fine.
