Is there any feedback you get when you report a Bug?
Dazkine
Post by Dazkine »
i did this http://www.makemkv.com/onlinehelp/testdump.html for 2 disc I ve problems with.
Upload the file(s) and write an email. But i didnt get any kind of feedback. Well thats a little bit of sad.
I dont know it anyone even reads the mails i sent to that emailadress.
Is that a normal behavior getting no answer at all?
Re: Is there any feedback you get when you report a Bug?
No guarantees on responses from Mike - USUALLY, the rip just starts working in a few days, if you have "Contact the server for updates" enabled.
If Mike requested that you send a Test Dump, though, you are more likely to get something of a follow up message. Not certain, just more likely.
