Hunger Games Mockingjay Part 1 - US Retail (title)
JoeBlivion
Re: Hunger Games Mockingjay Part 1 - US Retail (title)
#16 Post by JoeBlivion » Sat Mar 07, 2015 8:57 pm
My retail Version is from Costco, and the file that matches the segment map identified in other posts is 00707.mpls
Title information
Name: The Hunger Games: Mockingjay - Part 1 (English)
Source file name: 00707.mpls
Duration: 2:02:50
Chapters count: 16
Segment count: 20
Segment map: 503,520,516,510,511,506,507,514,518,509,519,517,501,505,502,512,515,504,513,508
File name: The_Hunger_Games_Mockingjay_-_Part_1_t379.mkv
This package is Blu-Ray + DVD + Digital HD
Bar code on the package is: 3198 20644
MichaelC
#17 Post by MichaelC » Sat Mar 07, 2015 10:31 pm
JoeBlivion wrote:My retail Version is from Costco, and the file that matches the segment map identified in other posts is 00707.mpls
Very interesting. My copy has exactly the same barcode and all data for the title matches yours except for the segment map. Mine (for 00707.mpls) is:
Segment map: 503,520,510,516,511,507,514,506,518,517,519,509,501,502,505,512,515,504,513,508
There are a couple of pairs that are swapped relative to yours. Quite curious.
#18 Post by Woodstock » Sat Mar 07, 2015 11:29 pm
Newest in that it's the first time you've encountered it - it's been around for over a year, on other titles. Ender's Game was the first I encountered it, but it was "old" when EG came out.
This message tells of where to find a Youtube video on how to locate the "right track": http://makemkv.com/forum2/viewtopic.php ... 39&#p38139
The tool mentioned, Process Monitor, isn't needed, because the Resource Monitor that comes with Windows is adequate.
MichaelC
#19 Post by MichaelC » Sun Mar 08, 2015 4:24 pm
Thanks, Woodstock. That's a clever method. I'll have to investigate to see if there's a Mac trick to accomplish the same thing. I've probably just got to set up a little bash shell to do it.
profplump
#20 Post by profplump » Sun Mar 08, 2015 8:41 pm
The "Process Monitor" or "Resource Monitor" step that lists open files on a Windows box can be replaced with this command on Unix/Mac systems:
lsof | grep -i mpls
That's "LiSt Open Files" and then filtered to only show things that contain MPLS (case-insensitive).
You can add additional filters to get less output, if you find the original overwhelming. For example, this would only list open MPLS files on a disk name "foo":
lsof | grep -i mpls | grep /Volumes/foo
Note that lsof is a snapshot tool -- it lists the open files at the moment it was run (though it can take several seconds to return). So unlike the Windows version where you want to setup the capture first and then review the logs, with this version you want to be playing first and then run the command.
I personally don't have any commercial Blu-ray software for Mac, or I'd try it myself. Anyone have recommendations?
EDIT: I tried the Macgo BR player; it does not access the disk via the filesystem (you can unmount it will the disk is playing), so it's not possible to use this method to determine which files it accesses.
theOtherDave
#21 Post by theOtherDave » Mon Mar 09, 2015 12:47 am
Just wanted to verify that, as seantnichols wrote, the following corresponds exactly to my copy of the blu-ray:
Source file name: 00697.mpls
Duration: 2:02:50
Chapters count: 16
Segment count: 20
Segment map: 510,512,519,504,517,505,507,513,520,502,516,509,508,518,503,506,501,515,511,514
File name: The_Hunger_Games_Mockingjay_-_Part_1_t416.mkv
GFOviedo
#22 Post by GFOviedo » Mon Mar 09, 2015 4:40 am
I bought the hard metal copy from Best Buy. It appears that it has the same mpls file of 553 as the Targer / Amazon.
GRUPPR
#23 Post by GRUPPR » Tue Mar 10, 2015 5:25 am
I also have a retail title. Viewed all segments and matched sequence to movie. Correct title and file data for me is listed below:
Name: The Hunger Games: Mockingjay - Part 1 (2014)
Source Filename: 707.mpls
Duration: 2:02:50
Chapter Count: 16
Segment Count : 20
Segment Map: 503, 520, 516, 510, 511, 506, 507, 514, 518, 509, 519, 517, 501, 505, 502, 512, 515, 504, 513, 508
File Name: The Hunger Games: Mockingjay - Part 1 (2014) t376.mkv
Important thing to note is segment map is identical to other post by JoeBlivion.
tanglin
#24 Post by tanglin » Wed Mar 11, 2015 2:22 am
How do I get this information out? I want to try as manual rip - any help with the string I need for the definition would be appreciated.
Duration: 2:02:50
Chapter Count: 16
Segment Count : 20
Edit - I see this is for a BR. I have a DVD.
zoxxo
#25 Post by zoxxo » Wed Mar 11, 2015 4:52 am
GFOviedo wrote:I bought the hard metal copy from Best Buy. It appears that it has the same mpls file of 553 as the Targer / Amazon.
I can confirm 553 for metal box...
hyjack90
#26 Post by hyjack90 » Fri Mar 13, 2015 8:44 am
This is correct for Red Box blu-ray
NOTE- no HD audio Just DD 5.1
Title information
Duration: 2:02:50
Chapters count: 16
Segment count: 20
File name: The_Hunger_Games_Mockingjay_-_Part_1_t415.mkv
rmiddle
#27 Post by rmiddle » Sat Mar 14, 2015 3:42 pm
theOtherDave wrote:Just wanted to verify that, as seantnichols wrote, the following corresponds exactly to my copy of the blu-ray:
Duration: 2:02:50
Chapters count: 16
Segment count: 20
The copy I got from Sams Club Blue-ray + Digital Copy No DVD mpls was 00697.mpls confirmed using procmon and windvd.
Robert
mrjones45
#28 Post by mrjones45 » Sat Mar 14, 2015 11:10 pm
Used 00553.mpls on Target purchase. Didn't work.
jcwillia1
#29 Post by jcwillia1 » Sun Mar 15, 2015 1:15 am
confirm 697 for redbox
whoo - these movies are IN TENSE.
thinksinc
#30 Post by thinksinc » Sun Mar 15, 2015 6:09 pm
Is there a confirmed MPLS for the Amazon combo-pack (BD, DVD + Digital HD)?
Thanks,
R
