American Hustle Forced Subs
Ripman
Post by Ripman »
I used MakeMKV with American Hustle, and it worked fine. The log is below. A tar file got created (v46) when I processed this BD. I did not send the tar file to support.
My question is about forced subtitles. American Hustle has a part about midway through where Robert DeNiro and another character speak in Arabic. When watching the BD, these show without making selections. When I used MakeMKV, I selected to create a forced subs track, but it was empty.
Any tips on this one please?
Debug log started at Tue Feb 10 20:00:32 2015 , written by MakeMKV v1.9.1 win(x86-release)
001005:0000 MakeMKV v1.9.1 win(x86-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Documents and Settings\Administrator/MakeMKV_log.txt
003006:0000 Opening files on harddrive at E:/0/17/American Hustle
DISCID=E0E505DC1DEAB177A69B68CFB47A0991F80107A1
003307:0000 File 00001.mpls was added as title #0
003307:0000 File 00021.mpls was added as title #1
003025:0000 Title #00022.mpls has length of 57 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00023.mpls has length of 84 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00025.mpls was added as title #2
003025:0000 Title #00026.mpls has length of 90 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00027.mpls has length of 94 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00028.mpls was added as title #3
003025:0000 Title #00029.mpls has length of 71 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00030.mpls has length of 47 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00031.mpls has length of 54 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00032.mpls was added as title #4
003307:0000 File 00033.mpls was added as title #5
003025:0000 Title #00096.mpls has length of 62 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00099.mpls was added as title #6
003307:0000 File 00102.mpls was added as title #7
003307:0000 File 00002.m2ts was added as title #8
003025:0000 Title #00003.m2ts has length of 51 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00004.m2ts has length of 78 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00006.m2ts was added as title #9
003025:0000 Title #00007.m2ts has length of 84 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00008.m2ts has length of 88 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00009.m2ts was added as title #10
003025:0000 Title #00010.m2ts has length of 65 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00011.m2ts has length of 41 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00012.m2ts has length of 48 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00013.m2ts was added as title #11
003307:0000 File 00014.m2ts was added as title #12
003025:0000 Title #00015.m2ts has length of 92 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00016.m2ts was added as title #13
003307:0000 File 00017.m2ts was added as title #14
003025:0000 Title #00018.m2ts has length of 98 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00019.m2ts was added as title #15
003025:0000 Title #00020.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00080.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00081.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00097.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00100.m2ts has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00103.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00104.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00116.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00205.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00208.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00220.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00221.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00222.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00223.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00224.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00225.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00226.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00227.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00228.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00229.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00249.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
005014:0000 Saving 1 titles into directory E:/0/17
004001:0000 Forced subtitles track #5 turned out to be empty and was removed from output file
005005:0080 1 titles saved
005036:0104 Copy complete. 1 titles saved.
Application exited at Tue Feb 10 20:41:50 2015
Ripman
Re: American Hustle Forced Subs
Post by Ripman »
Regarding the same, attached is a screen-shot of the title selection and audio tracks that I used when processing.
http://s7.postimg.org/pjmlevid7/Am_Hust ... ection.jpg
You probably have a single subtitle track which ONLY contains those "forced" subtitles, but they are NOT marked as "forced".
The use of the forced flag (which is what MakeMKV uses when you click "forced only" is actually rather rare. I only have one BD (Avatar) that "properly" uses the forced flag. Everything else uses a separate track, or burn the forced subtitles into the video.
Ripman
Post by Ripman »
Thanks Woodstock. This is resolved. I checked the resultant mkv, and the forced subs were included in the main subtitle track.
I did another post just after the OP where I attached a screen-shot of the sub tracks I had ticked. Once the mod checks it, it should get posted back here too.
