Hunger Games Mockingjay Part 1 - rental via RB
bk7777
#1 Post by bk7777 » Fri Mar 06, 2015 6:01 pm
Any on figured out which mpls is the right one on the RB rental version?
Looking forward to the answer.
Thanks,
gamecaptor
Re: Hunger Games Mockingjay Part 1 - rental via RB
#2 Post by gamecaptor » Fri Mar 06, 2015 6:18 pm
Someone else has a thread going on this as well:
http://www.makemkv.com/forum2/viewtopic ... mockingjay
jriddle
#3 Post by jriddle » Fri Mar 06, 2015 6:59 pm
"gamecaptor"]Someone else has a thread going on this as well:
You linked to a "retail" version while the op is referring to a RB "rental" version which may or may not be the same therefore there needs to be separate threads.
John
wildspirit97
#4 Post by wildspirit97 » Fri Mar 06, 2015 9:13 pm
Source file name: 00697.mpls
Duration: 2:02:50
Chapters count: 16
Segment count: 20
Segment map: 510,512,519,504,517,505,507,513,520,502,516,509,508,518,503,506,501,515,511,514
File name: The_Hunger_Games_Mockingjay_-_Part_1_t417.mkv
this is RB version
bk7777
#5 Post by bk7777 » Fri Mar 06, 2015 10:18 pm
Thank you so much.
everything matched as you posted.
gamecaptor
#6 Post by gamecaptor » Fri Mar 06, 2015 10:55 pm
Woops, missed that part. Thanks for pointing it out.
zeroepoch
#7 Post by zeroepoch » Fri Mar 06, 2015 11:46 pm
Just wanted to confirm 00697.mpls for the Redbox Rental. Did the splicing and came up with the same result. For me with minimum length 600 sec it was track 290 instead of 417.
jbbrown
#8 Post by jbbrown » Sat Mar 07, 2015 3:31 am
wildspirit97 wrote:Source file name: 00697.mpls
Duration: 2:02:50
Chapters count: 16
Segment count: 20
this is RB version
I just got the movie from Family Video. Will all US rentals be the same?
bk7777
#9 Post by bk7777 » Sat Mar 07, 2015 5:09 am
confirming that 697.mpls it the correct set for RB rentals.
Cut it watched it perfect.
Thank you all...
Brian
wildspirit97
#10 Post by wildspirit97 » Sat Mar 07, 2015 10:28 am
I don't know, but if your your segment map matches on the same title I would say it's the same.
jbbrown
#11 Post by jbbrown » Sat Mar 07, 2015 12:21 pm
Yes, the segment map does match. Thanks!
strobelighthos
#12 Post by strobelighthos » Sun Mar 08, 2015 3:26 am
Does anyone know what mpls is correct for the Netflix bluray version?
jspoltore
#13 Post by jspoltore » Mon Mar 09, 2015 1:36 pm
How would i enter the string into the manual mode for the RB version?
spotts
ellhef
#14 Post by ellhef » Tue Mar 17, 2015 1:27 pm
strobelighthos wrote:Does anyone know what mpls is correct for the Netflix bluray version?
I see the same information as above for 00697.mpls on this version, including segment map. Suspect it's the same...
cpitchford
#15 Post by cpitchford » Tue Mar 17, 2015 9:05 pm
Using a player app and process monitor on windows 7, it looks like 871 is the correct playlist for the steelbook version from Amazon UK. I'm ripping now but I've not checked the result yet
