Programming changed suggestion to human interface
bk7777
Post by bk7777 »
Programming changed suggestion to human interface.
Since lionsgate keep adding more and more dud filesets. It would be not to have an option to "unselect all"
It took me 15 min to uncheck all the boxes on mocking jay.
Looking for a simple solution.
Thanks,
Brian
Re: Programming changed suggestion to human interface
Simpler than using the mouse to RIGHT CLICK on the selections area, and then selecting "Unselect All"? Not sure it's going to happen very soon....
bk7777
Post by bk7777 »
Well thank you I did not know that was an option.
Works great. Now I know better.
Thank you,
Brian
Just a hint that took me a while to learn - more and more programs are adding "context menus" to the right mouse button, and some are adding them to the center button. It's always worth a try, unless you're on a dialog box that says, "Drop car from 30 meters onto box of kittens, Yes/No/Go Higher", and it's attached to a real crane.... :)
