fonephixer
Post
by fonephixer » Fri Mar 06, 2015 7:38 pm
Hey! first off, love the program!
This is my first issue Ive had using it, and I am wondering if this is some new type of encryption.
My log looks like this.
Saving 1 titles into directory C:/Users/FonePhiXeR/Videos
AV synchronization issues were found in file 'C:/Users/FonePhiXeR/Videos/title13.mkv' (title #14)
AV sync issue in stream 0 at 0:08:15.661 : video frame timecode differs by +27.827s
AV sync issue in stream 0 at 0:08:22.952 : video frame timecode differs by +27.827s
AV sync issue in stream 0 at 0:08:29.909 : video frame timecode differs by +27.827s
AV sync issue in stream 0 at 0:08:30.293 : video frame timecode differs by +27.827s
AV sync issue in stream 0 at 0:08:30.877 : video frame timecode differs by +27.827s
AV sync issue in stream 0 at 0:08:33.663 : video frame timecode differs by +27.827s
AV sync issue in stream 1 at 0:08:15.456 with duration of 3947.07ms : audio gap - 123.345 missing frame(s)
AV sync issue in stream 0 at 0:08:37.083 : video frame timecode differs by +27.827s
AV sync issue in stream 0 at 0:08:37.967 : video frame timecode differs by +27.827s
AV sync issue in stream 0 at 0:08:39.385 : video frame timecode differs by +27.827s
AV sync issue in stream 0 at 0:08:39.802 : video frame timecode differs by +27.827s
AV sync issue in stream 0 at 0:08:39.802 : too many video frames with invalid timecodes, future messages will be suppressed
AV sync issue in stream 1 at 0:08:43.296 with duration of 32ms : audio gap - 1 missing frame(s)
Failed to save title 13 to file C:/Users/FonePhiXeR/Videos/title13.mkv
Is there anything I can do to make this work?
Thanx in advance for all your help!
Post
by Woodstock » Fri Mar 06, 2015 7:56 pm
For the log, do you have "Debug logging" turned on? Normally, there would be a bit more information for a fail-to-save. The synchronization messages are fairly routine, and should not cause the rip to fail.
PBzeer
Post
by PBzeer » Fri Mar 06, 2015 9:32 pm
Ok, here's what's happened with my attempt.
First, it doesn't display the proper title to save (AFIK), My player shows title 33 as being the movie, the list stops at source ID: 32
Tried to save the only available title (28) with the correct runtime, and got a LIBMKV TRACE: Exception Error reading input, at about the 590M point of 6 gigs. Does a whole bunch of Code 0's just before stopping.
Tried attaching log, but says attachment quota reached.
Post
by Woodstock » Fri Mar 06, 2015 9:58 pm
Attachments are pretty much screwed up on this board, but, if it's under 60K in size, you can simply click the "Code" button above the editor button, and past the log in between the tags that will be inserted.
Each of the debug codes indicates a place where the data stream is non-standard, and MakeMKV has to apply a "work around" to try to make things sane again. The codes tell Mike which ones were tried.
PBzeer
Post
by PBzeer » Fri Mar 06, 2015 10:14 pm
Okay, I'll try the code thing
DEBUG: Code 0 at !#.uCa}y0[n+|eZx@RY:213132491
DEBUG: Code 0 at !#.uCa}y0[n+|eZx@RY:121262693
DEBUG: Code 0 at cX{I_[Yz(a<&?9u.V!} :213130559
DEBUG: Code 42 at cX{I_[Yz(a<&?9u.V!} :29393286
DEBUG: Code 0 at fd:}hC.U)'&t'PX'`)9d(:29399013
DEBUG: Code 0 at oZ-NuUuaPVlvav4\*"8:213132054
That's before it starts saving. Then here's where it stops (got to 611 MB this time)
DEBUG: Code 0 at cX{I_[Yz(a<&?9u.V!} :29394482
DEBUG: Code 384489 at cX{I_[Yz(a<&?9u.V!} :29393286
Failed to save title 10 to file M:/Movies/Hunger Games, The - Mockingjay Part 1/title10.mkv
0 titles saved, 1 failed
Handbrake shows Title 33 as being the feature as well (though it won't save it either).
caos1978
Post
by caos1978 » Sat Mar 07, 2015 1:02 am
I have the Region 1/Standard disc and for that VLC menu-based playback shows title 22 as the "correct" one. It's thrown out on a full-automatic pass and on semi-auto manual (title specified) it also fails.
Here is the debug log:
Debug log started at Fri Mar 6 22:03:01 2015 , written by MakeMKV v1.9.1 linux(x64-release)
001005:0000 MakeMKV v1.9.1 linux(x64-release) started
001004:0000 Debug logging enabled, log will be saved as /home/caos1978/MakeMKV_log.txt
001003:0020 DEBUG: Code 0 at <Q6Om)&YJVm~_mB]F<=s\E}:213130122
001003:0020 DEBUG: Code 10551300 at zM\V2rVs3VqNfb?]:213142128
001003:0020 DEBUG: Code 0 at zM\V2rVs3VqNfb?]:213143301
001003:0020 DEBUG: Code 0 at ,ebcjmUa"jGCILZ4*u:29394229
003035:0000 CellWalk algorithm failed (structure protection is too tough?), trying CellTrim algorithm
003037:0000 Cells 1-1 were removed from title start
003028:0000 Title #22 was added (19 cell(s), 2:02:32)
001003:0020 DEBUG: Code 233 at tnWUjXqXYZQYKDlQEuCnOszi:0
005014:0000 Saving 1 titles into directory /media/rips/the.hunger.games-mocking.jay.part1
001003:0020 DEBUG: Code 0 at -%k%4542M!1_$Qa:79t:213132491
vobs=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
001003:0020 DEBUG: Code 0 at -%k%4542M!1_$Qa:79t:121262693
001003:0020 DEBUG: Code 0 at G>PW48,rIZcY.dJ.A%`#:213130559
001003:0020 DEBUG: Code 41 at G>PW48,rIZcY.dJ.A%`#:29393286
001003:0020 DEBUG: Code 0 at szB4$v+ycF^$ISWp'3w`g:29399013
001003:0020 DEBUG: Code 0 at QiS$*\&Haz2I]cv/RSs:213132054
vobs=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
001003:0020 DEBUG: Code 373744 at G>PW48,rIZcY.dJ.A%`#:29393286
005003:0000 Failed to save title 0 to file /media/rips/the.hunger.games-mocking.jay.part1/title22.mkv
005004:0080 0 titles saved, 1 failed
Application exited at Fri Mar 6 23:33:57 2015
premlor
Post
by premlor » Sat Mar 07, 2015 2:34 am
So I'm getting the same error message with this movie. Any solutions? It needs to be returned tomorrow.
spinnacre
Post
by spinnacre » Sat Mar 07, 2015 3:05 am
MakeMKV reads 594 titles... I tried the first one (having not run into this obfuscation technique before) and scenes were more and more jumbled beyond the first twenty minutes. Still need to figure it out so I can backup my
$9.96 copy to my library.
bansheesiryn
Post
by bansheesiryn » Sat Mar 07, 2015 4:08 am
I tried doing it through manual mode to get title 33, it didn't work either. Any other ideas on how to rip this DVD?
drmda
Post
by drmda » Sat Mar 07, 2015 4:28 am
I've got the RB DVD that just came out today.
I'm getting failures also;
Here's my debug log:
Saving 1 titles into directory C:/Users/Public/Videos/MKV Files/The Hunger Games - Mockingjay Part 1
DEBUG: Code 0 at _}>2]/?KC0L=d8 `"oE:213132491
DEBUG: Code 0 at _}>2]/?KC0L=d8 `"oE:121262693
DEBUG: Code 0 at y6*vfE*%I]?KB[pfW2x&:213130559
DEBUG: Code 41 at y6*vfE*%I]?KB[pfW2x&:29393286
DEBUG: Code 0 at {Sd%j8Wv.P@.V@bGTwF]7:29399013
DEBUG: Code 0 at 7j,,jN9<AEOAX qUp,\:213132054
DEBUG: Code 373744 at y6*vfE*%I]?KB[pfW2x&:29393286
Failed to save title 4 to file C:/Users/Public/Videos/MKV Files/The Hunger Games - Mockingjay Part 1/title04.mkv
So, any of you MAKEMKV experts, what's going on?
FWIW, I tried making a backup .iso of the disc using BurnAware. This seemed to hang at 404 of 8144 MB.
Thanks,
Bob
PBzeer
Post
by PBzeer » Sat Mar 07, 2015 5:01 am
My Handbrake log showed Feature as Title 33 in VTS_22 TTN_1. There are 38 titles in whole, but the MakeMKV list stops at 32, though it shows all 38 during opening of disc.
I also tried it on my other laptop, with the same results.
Post
by Woodstock » Sat Mar 07, 2015 3:44 pm
As mentioned in the FAQ, email the logs and other files to
support@makemkv.com so that Mike has something to work with. The more examples of the problem that he can get, the better the fix.
drmda
Post
by drmda » Sun Mar 08, 2015 12:59 am
FWIW:
I've read elsewhere today that The Hunger Games - Mockingjay Part 1 DVD (and BluRay) uses a new copy protection scheme.
I don't think the latest version of makemkv can save titles protected with this new scheme.
I know there are other programs that have already posted workarounds. Hopefully makemkv will have fixes soon.
Please send your Error Log and IFO files as described in
http://www.makemkv.com/faq/item/8
There more the merrier....
awboyd
Post
by awboyd » Mon Mar 09, 2015 7:44 pm
Same issue, log below:
MakeMKV v1.9.1 win(x64-release) started
Debug logging enabled, log will be saved as C:\Users\MakeMKV_log.txt
Title #2 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #3 has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #4 has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #5 has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #6 was added (6 cell(s), 0:11:15)
Title #7 was added (6 cell(s), 0:11:15)
Title #8 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #9 was added (1 cell(s), 0:04:10)
Title #10 has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #12 was added (1 cell(s), 0:29:35)
Title #15 was added (24 cell(s), 2:07:57)
Cells 2-6 were skipped due to cell commands (structure protection?)
Title #16 was added (20 cell(s), 2:07:31)
Title #17 was added (20 cell(s), 2:07:31)
Title #18 was added (20 cell(s), 2:07:31)
DEBUG: Code 10551300 at 2v\x6:dUo2"1l{@\:213142128
DEBUG: Code 0 at 2v\x6:dUo2"1l{@\:213143301
DEBUG: Code 0 at <|C!&I&2z{,(s O7|P:29394229
Title #19 was added (19 cell(s), 2:02:32)
Title #20 was added (19 cell(s), 2:02:32)
Title #23 was added (20 cell(s), 2:07:31)
Title #24 was added (24 cell(s), 2:07:57)
Title #25 was added (19 cell(s), 2:02:32)
Title #26 was added (19 cell(s), 2:02:32)
Title #27 was added (24 cell(s), 2:07:57)
Title #28 was added (24 cell(s), 2:07:57)
Title #29 was added (24 cell(s), 2:07:57)
Title 1 in VTS 13 is equal to title 1 and was skipped
Title 2 in VTS 13 is equal to title 1 and was skipped
Title 1 in VTS 17 is equal to title 1 and was skipped
Saving 1 titles into directory M:/Video
Failed to save title 8 to file M:/Video/title08.mkv
