Can't play MKV in WMP
m4rky
#1 Post by m4rky » Wed Feb 11, 2009 10:10 am
I have successfully used MakeMKV to create MKV files but these files won't play in Windows Media Player only VLC?
Is there a particular code I need to make them play in WMP or do I need to re-encode the MKV file into something WMP can play?
bigzaj
Re: Can't play MKV in WMP
#2 Post by bigzaj » Wed Feb 11, 2009 3:20 pm
Have tried installed codecs? A simple solution would be installed the Combined Community Codec Pack or you can install the codecs you want manually.
m4rky
#3 Post by m4rky » Thu Feb 12, 2009 4:38 pm
I don't really want to install a Codec Pack as I have spent weeks trying to get my Media PC setup right.
Does any one know which Codec is required?
#4 Post by mike admin » Fri Feb 13, 2009 10:01 am
you need haali splitter to handle MKV file format and individual codecs for particular formats inside MKV - usually mpeg2, mpeg4, VC-1, DD, DTS.
m4rky
#5 Post by m4rky » Thu Feb 19, 2009 12:39 pm
Thanks, I thought I already had Haali on as I can process any other MKV file no problem.
Its just the ones I have created that contain MPEG2 video that don't work
m4rky
#6 Post by m4rky » Fri Feb 27, 2009 9:38 am
mike admin wrote:you need haali splitter to handle MKV file format and individual codecs for particular formats inside MKV - usually mpeg2, mpeg4, VC-1, DD, DTS.
Thanks, I finally got around to checking if I had this installed.
I didn't. So once installed I can now play the MKV files I have created with MakeMKV :D
I don't understand how other .MKV files with HD content worked without the media splitter??
Never mind, thanks for the help
