Hunger Games Mockingjay Part 1 - US Retail (title)
seantnichols
Post by seantnichols » Fri Mar 06, 2015 5:48 pm
So has anyone identified the correct title yet? There are over 600 on this one. :P
gamecaptor
Re: Hunger Games Mockingjay Part 1 - US Retail (title)
Post by gamecaptor » Fri Mar 06, 2015 6:21 pm
Ya, trying to narrow it down now.
seantnichols
Post by seantnichols » Fri Mar 06, 2015 7:45 pm
I am 99% sure the order is this:
510,512,519,504,517,505,507,513,520,502,516,509,508,518,503,506,501,515,511,514
I have watched the beginning and end of each segment to make sure they flow correctly, also going off what I remember from seeing it in theaters. I just need to find the title that matches that segment map now. I will post back when I find it.
seantnichols
Post by seantnichols » Fri Mar 06, 2015 8:02 pm
697.mpls is the one, 100%.
photonic
Post by photonic » Fri Mar 06, 2015 9:32 pm
I have the Target retail copy which does not have a 697.mpls or a segment map that doesn't start with 503. I'm trying 553.mpls as suggested in another thread as I do have that one.
funjon
Post by funjon » Sat Mar 07, 2015 12:36 am
The Amazon retail copy looks to be like the Target retail copy - no 697.mpls or segment maps that don't start with 503.
553.mpls on my copy has the following order:
503,514,511,512,501,506,502,517,505,509,516,510,513,504,519,515,507,520,518,508
I'll start with this one (sadly I didn't get to see the movie in the theater, but I'll throw this in the PS3 after and compare).
thirdgen89gta
Post by thirdgen89gta » Sat Mar 07, 2015 4:14 am
funjon wrote:The Amazon retail copy looks to be like the Target retail copy - no 697.mpls or segment maps that don't start with 503.
I also bought mine from Amazon, and while The 553.mpls appears to be correct as all of the segments match up, my segments don't match yours. I need to watch the movie in full to know for sure. I'll edit this post after I've watched it. Mine is the BR + DVD + Digital combo.
Title information
Name: The Hunger Games: Mockingjay - Part 1
Source file name: 00553.mpls
Duration: 2:02:50
Chapters count: 16
Segment count: 20
Segment map: 503,520,516,510,511,506,507,514,518,509,519,517,501,505,502,512,515,504,513,508
File name: The_Hunger_Games_Mockingjay_-_Part_1_t296.mkv
funjon
Post by funjon » Sat Mar 07, 2015 4:47 am
thirdgen89gta wrote: I also bought mine from Amazon, and while The 553.mpls appears to be correct as all of the segments match up, my segments don't match yours. I need to watch the movie in full to know for sure. I'll edit this post after I've watched it. Mine is the BR + DVD + Digital combo.
Title information
Duration: 2:02:50
Chapters count: 16
Segment count: 20
Somehow I accidentally ripped and posted 533, not 553. (and 533 is definitely the wrong one). I am re-ripping 553 now.
Mine is also the BR+DVD+Digital combo, and my segment map for 553 matches yours. Please disregard my previous post.
smikkelsen
Post by smikkelsen » Sat Mar 07, 2015 4:52 am
I have the Blu Ray Digital movie combo from Amazon. I ripped 0053.mpls with segment map: 503,520,516,510,511,506,507,514,518,509,519,517,501,505,502,512,515,504,513,508
I went through chapter by chapter and compared with digital copy at same time stamps, and all frames lined up.
I just thought I would register so I could post this and hopefully save someone some time. This was a joke how many playlists there are to choose from.
funjon
Post by funjon » Sat Mar 07, 2015 8:04 am
Confirmed, the correct segment map for the Amazon/Target BD/DVD/Digital Combo pack
Just finished watching the disc next to my rip, side by side. Happy ripping!
profplump
Post by profplump » Sat Mar 07, 2015 9:15 am
Is matching up the first/last frames a reliable way to determine linearity? I've never tried myself, and I ask because that seems like something I could automate, or at least like 90% automate, with some perl and a makemkv binary.
Timothy Wright
Post by Timothy Wright » Sat Mar 07, 2015 12:09 pm
I have a Redbox DVD rental. I have tried every combination of DVD structure removal method and six possible movie play lists and in every attempt all I can recover from the DVD is the two coming attraction previews. Everything else results in a "Failed to save file" error message.
However after watching the movie I don't know how keen I am to add it to my collection.
MichaelC
Post by MichaelC » Sat Mar 07, 2015 3:11 pm
I've got the Amazon version. Tried 553 and got the following in the log:
Saving 1 titles into directory /Volumes/Data/No Backup/Movies/To Do
AV synchronization issues were found in file '/Volumes/Data/No Backup/Movies/To Do/The_Hunger_Games_Mockingjay_-_Part_1_t296.mkv' (title #297)
AV sync issue in stream 2 at 0:13:54.291 with duration of 12.208ms : encountered overlapping frame, audio skew is +12.208ms
AV sync issue in stream 1 at 0:14:28.033 with duration of 0.458ms : encountered overlapping frame, audio skew is +1.166ms
AV sync issue in stream 1 at 0:14:28.035 with duration of 0.833ms : 1 frame(s) dropped to reduce audio skew to +0.333ms
AV sync issue in stream 2 at 0:14:28.033 with duration of 17.958ms : encountered overlapping frame, audio skew is +30.166ms
AV sync issue in stream 2 at 0:14:48.470 with duration of 10.916ms : encountered overlapping frame, audio skew is +41.083ms
AV sync issue in stream 2 at 0:14:48.512 with duration of 32ms : 1 frame(s) dropped to reduce audio skew to +9.083ms
AV sync issue in stream 2 at 0:15:27.468 with duration of 10.708ms : encountered overlapping frame, audio skew is +19.791ms
AV sync issue in stream 1 at 0:15:27.469 with duration of 0.833ms : 1 frame(s) dropped to reduce audio skew to +0.125ms
AV sync issue in stream 2 at 0:23:58.228 with duration of 23.75ms : encountered overlapping frame, audio skew is +43.541ms
AV sync issue in stream 2 at 0:23:58.272 with duration of 32ms : 1 frame(s) dropped to reduce audio skew to +11.541ms
AV sync issue in stream 2 at 0:24:25.672 with duration of 11.916ms : encountered overlapping frame, audio skew is +23.458ms
AV sync issue in stream 2 at 0:24:58.997 with duration of 19.041ms : encountered overlapping frame, audio skew is +42.5ms
AV sync issue in stream 2 at 0:24:59.040 with duration of 32ms : 1 frame(s) dropped to reduce audio skew to +10.5ms
AV sync issue in stream 1 at 0:24:58.998 with duration of 0.833ms : 1 frame(s) dropped to reduce audio skew to +0ms
AV sync issue in stream 2 at 0:26:03.311 with duration of 5.75ms : encountered overlapping frame, audio skew is +16.25ms
AV sync issue in stream 1 at 0:37:00.259 with duration of 0.375ms : encountered overlapping frame, audio skew is +1.125ms
AV sync issue in stream 1 at 0:37:00.260 with duration of 0.833ms : 1 frame(s) dropped to reduce audio skew to +0.291ms
AV sync issue in stream 2 at 0:37:00.259 with duration of 12.041ms : encountered overlapping frame, audio skew is +28.291ms
AV sync issue in stream 2 at 0:37:54.355 with duration of 16.291ms : encountered overlapping frame, audio skew is +44.583ms
AV sync issue in stream 2 at 0:37:54.400 with duration of 32ms : 1 frame(s) dropped to reduce audio skew to +12.583ms
AV sync issue in stream 2 at 0:39:01.213 with duration of 21.541ms : encountered overlapping frame, audio skew is +34.125ms
AV sync issue in stream 2 at 0:39:01.248 with duration of 32ms : 1 frame(s) dropped to reduce audio skew to +2.125ms
AV sync issue in stream 1 at 0:39:01.213 with duration of 0.708ms : encountered overlapping frame, audio skew is +1.125ms
AV sync issue in stream 1 at 0:39:01.215 with duration of 0.833ms : 1 frame(s) dropped to reduce audio skew to +0.291ms
AV sync issue in stream 2 at 0:39:58.312 with duration of 21.291ms : encountered overlapping frame, audio skew is +23.416ms
AV sync issue in stream 2 at 1:05:34.513 with duration of 22.666ms : encountered overlapping frame, audio skew is +46.083ms
AV sync issue in stream 2 at 1:05:34.560 with duration of 32ms : 1 frame(s) dropped to reduce audio skew to +14.083ms
AV sync issue in stream 1 at 1:05:34.513 with duration of 0.333ms : encountered overlapping frame, audio skew is +1.083ms
AV sync issue in stream 1 at 1:05:34.515 with duration of 0.833ms : 1 frame(s) dropped to reduce audio skew to +0.25ms
AV sync issue in stream 1 at 1:06:30.570 with duration of 0.833ms : 1 frame(s) dropped to reduce audio skew to +0.083ms
AV sync issue in stream 2 at 1:06:30.569 with duration of 8ms : encountered overlapping frame, audio skew is +22.083ms
AV sync issue in stream 2 at 1:06:54.719 with duration of 10.875ms : encountered overlapping frame, audio skew is +32.958ms
AV sync issue in stream 2 at 1:06:54.752 with duration of 32ms : 1 frame(s) dropped to reduce audio skew to +0.958ms
AV sync issue in stream 2 at 1:20:57.853 with duration of 2.041ms : encountered overlapping frame, audio skew is +3ms
AV sync issue in stream 2 at 1:21:56.828 with duration of 0.416ms : encountered overlapping frame, audio skew is +3.416ms
AV sync issue in stream 1 at 1:22:31.530 with duration of 0.833ms : 1 frame(s) dropped to reduce audio skew to +0.083ms
AV sync issue in stream 2 at 1:22:31.529 with duration of 18.666ms : encountered overlapping frame, audio skew is +22.083ms
AV sync issue in stream 2 at 1:23:46.771 with duration of 22.166ms : encountered overlapping frame, audio skew is +44.25ms
AV sync issue in stream 2 at 1:23:46.816 with duration of 32ms : 1 frame(s) dropped to reduce audio skew to +12.25ms
Forced subtitles track #4 turned out to be empty and was removed from output file
Forced subtitles track #5 turned out to be empty and was removed from output file
Forced subtitles track #6 turned out to be empty and was removed from output file
1 titles saved
Post by Woodstock » Sat Mar 07, 2015 4:02 pm
Sync issues are common with disks that have "seamless branching", where a title can be made up of parts stored in a variety of files on the disk. The messages are just letting you know that MakeMKV is fixing them.
MichaelC
Post by MichaelC » Sat Mar 07, 2015 4:27 pm
Woodstock wrote:. The messages are just letting you know that MakeMKV is fixing them.
A few of the errors were about a frame and a half, although most were within a frame. That's just on the edge of being able to see a lipsync problem. Given the hundreds of choices on this particular disk, is there one that should be 'perfect' with no adjustments?
This disk seems to bring the possible confusion to a whole new level (with hundreds of titles). I suppose this is the publishers' newest attempt to thwart those of us who'd rather have the movie on our servers than dig around in the video closet.
