Hunger Games Mockingjay Part 1 - rental via RB
bk7777
Post by bk7777 »
Any on figured out which mpls is the right one on the RB rental version?
Looking forward to the answer.
Thanks,
gamecaptor
Re: Hunger Games Mockingjay Part 1 - rental via RB
Post by gamecaptor »
Someone else has a thread going on this as well:
http://www.makemkv.com/forum2/viewtopic ... mockingjay
jriddle
Post by jriddle »
"gamecaptor"]Someone else has a thread going on this as well:
You linked to a "retail" version while the op is referring to a RB "rental" version which may or may not be the same therefore there needs to be separate threads.
John
wildspirit97
Post by wildspirit97 »
Source file name: 00697.mpls
Duration: 2:02:50
Chapters count: 16
Segment count: 20
Segment map: 510,512,519,504,517,505,507,513,520,502,516,509,508,518,503,506,501,515,511,514
File name: The_Hunger_Games_Mockingjay_-_Part_1_t417.mkv
this is RB version
bk7777
Post by bk7777 »
Thank you so much.
everything matched as you posted.
gamecaptor
Woops, missed that part. Thanks for pointing it out.
zeroepoch
Post by zeroepoch »
Just wanted to confirm 00697.mpls for the Redbox Rental. Did the splicing and came up with the same result. For me with minimum length 600 sec it was track 290 instead of 417.
jbbrown
Post by jbbrown »
wildspirit97 wrote:Source file name: 00697.mpls
Duration: 2:02:50
Chapters count: 16
Segment count: 20
this is RB version
I just got the movie from Family Video. Will all US rentals be the same?
bk7777
Post by bk7777 »
confirming that 697.mpls it the correct set for RB rentals.
Cut it watched it perfect.
Thank you all...
Brian
wildspirit97
I don't know, but if your your segment map matches on the same title I would say it's the same.
jbbrown
Post by jbbrown »
Yes, the segment map does match. Thanks!
strobelighthos
Post by strobelighthos »
Does anyone know what mpls is correct for the Netflix bluray version?
jspoltore
Post by jspoltore »
How would i enter the string into the manual mode for the RB version?
spotts
ellhef
Post by ellhef »
strobelighthos wrote:Does anyone know what mpls is correct for the Netflix bluray version?
I see the same information as above for 00697.mpls on this version, including segment map. Suspect it's the same...
cpitchford
Post by cpitchford »
Using a player app and process monitor on windows 7, it looks like 871 is the correct playlist for the steelbook version from Amazon UK. I'm ripping now but I've not checked the result yet
