Hunger Games Mockingjay Part 1 - rental via RB
Any on figured out which mpls is the right one on the RB rental version?
Looking forward to the answer.
Thanks,
Thanks,
Re: Hunger Games Mockingjay Part 1 - rental via RB
Someone else has a thread going on this as well:
http://www.makemkv.com/forum2/viewtopic ... mockingjay
"gamecaptor"]Someone else has a thread going on this as well:
You linked to a "retail" version while the op is referring to a RB "rental" version which may or may not be the same therefore there needs to be separate threads.
John
John
Source file name: 00697.mpls
Duration: 2:02:50
Chapters count: 16
Segment count: 20
Segment map: 510,512,519,504,517,505,507,513,520,502,516,509,508,518,503,506,501,515,511,514
File name: The_Hunger_Games_Mockingjay_-_Part_1_t417.mkv
this is RB version
Duration: 2:02:50
Chapters count: 16
Segment count: 20
this is RB version
Thank you so much.
everything matched as you posted.
Woops, missed that part. Thanks for pointing it out.
Just wanted to confirm 00697.mpls for the Redbox Rental. Did the splicing and came up with the same result. For me with minimum length 600 sec it was track 290 instead of 417.
I just got the movie from Family Video. Will all US rentals be the same?wildspirit97 wrote:Source file name: 00697.mpls
Duration: 2:02:50
Chapters count: 16
Segment count: 20
this is RB version
confirming that 697.mpls it the correct set for RB rentals.
Cut it watched it perfect.
Thank you all...
Brian
Thank you all...
Brian
I don't know, but if your your segment map matches on the same title I would say it's the same.jbbrown wrote:
Yes, the segment map does match. Thanks!wildspirit97 wrote:I don't know, but if your your segment map matches on the same title I would say it's the same.jbbrown wrote:
Does anyone know what mpls is correct for the Netflix bluray version?
How would i enter the string into the manual mode for the RB version?
spotts
spotts
I see the same information as above for 00697.mpls on this version, including segment map. Suspect it's the same...strobelighthos wrote:Does anyone know what mpls is correct for the Netflix bluray version?
Using a player app and process monitor on windows 7, it looks like 871 is the correct playlist for the steelbook version from Amazon UK. I'm ripping now but I've not checked the result yet
