To each their own what? I simply corrected your incorrect statement that identifying the proper sub would be tricky/time consuming which has no bearing whatsoever on the fact that I would like to be able to rip them automatically too.matt198t wrote:You're right there isn't but I actually like to watch my content rather than concentrating on the bottom of the screen on where the subs should show up, but each to their own!
does the TV series Lost have forced subtitles
Chetwood
Re: does the TV series Lost have forced subtitles
matt198t
Chetwood wrote:To each their own what? I simply corrected your incorrect statement that identifying the proper sub would be tricky/time consuming which has no bearing whatsoever on the fact that I would like to be able to rip them automatically too.matt198t wrote:You're right there isn't but I actually like to watch my content rather than concentrating on the bottom of the screen on where the subs should show up, but each to their own!
bw001
Lost has forced subtitles in seasons 3 - 6, but they're hardcoded into the video. No need to worry about forced subtitles.
Also, as noted, seasons 3 & 4 use LPCM which can be converted to FLAC by MakeMKV using Advanced Settings.
Chetwood
Unless of course you are German, which means you need forced German subs to translate the hardcoded English items where Korean is spoken.bw001 wrote:Lost has forced subtitles in seasons 3 - 6, but they're hardcoded into the video. No need to worry about forced subtitles.
tatts4Life
Interesting. So if I ripped the subtitles but turn them off it will still force the Korean?bw001 wrote:Lost has forced subtitles in seasons 3 - 6, but they're hardcoded into the video. No need to worry about forced subtitles.
Chetwood
Hardcoded is hardcoded.
