Ripping Ironman 3 failed, ASUS BW-12B1S crashes & disappears
xiaohundan
Post by xiaohundan » Thu Mar 05, 2015 9:35 pm
I have been using MakeMKV to rip my 15 of my blu-rays collection into MKV files. Recently ripping started failing and crashes my writer, ASUS BW-12B1S. MakeMKV would rip half-way and failed, no files get created, and drive would become inaccessible (it would disappear from Windows File Explorer). I have this drive for a month, and started ripping 3 weeks ago.
Blu-ray currently failing:
Ironman, Ironman 3, Avenger & TMNT.
(Note: I tried ripping titles that I've previously ripped, they would fail)
Here is my observation:
1) Insert any blu-ray and use MakeMKV to rip it into MKV
2) MakeMKV starts ripping process and I could see it progresses via progress bar
3) Ripping would fail halfway and report failure. This time, the Blu-Ray drive disappears from Windows File Explorer and is no longer accessible. Reinsert Blu-ray does not help.
4) After rebooting the computer, the drive reappears and becomes accessible. In the attempt to rip blu-ray again, same issue observed
5) I suspect the drive crashed which brings the drive into inaccessible mode.
Not sure if this is software or hardware issue. I'm posting here in case someone is experiencing similar issue.
Re: Ripping Ironman 3 failed, ASUS BW-12B1S crashes & disapp
Post by Woodstock » Thu Mar 05, 2015 10:38 pm
More likely, the motherboard lost communications with the drive, which caused the error. Resetting the computer resets the interface to the drive, and communications works again... until whatever failed fails again.
Given that MakeMKV will run the drive up to its full speed, you could have something that is overheating, either in the drive itself or on the motherboard. You can test this by trying to copy files from the drive, if you have something that Windows won't limit the speed on. If you were running Linux, I'd suggest using 'dd' to copy a disk image, using a large block size, because it can spin optical disks up about as well as MakeMKV does.
Smithcraft
Post by Smithcraft » Sun Mar 08, 2015 9:56 pm
That appears to be an external drive, so make sure it isn't bus powered, and is plugged into a power adapter.
SC
