Lost S01E24 keeps failing
tatts4Life
Post by tatts4Life » Wed Mar 04, 2015 2:28 am
So I'm working through my movies and TV shows and when I got to Lost season 1 episode 24 which is the first half of the season finale I keep getting a failed to save message. More specifically I'm getting this. Error 'SCSI error - MEDIUM ERROR:L -EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00011.m2ts' at offset '260438016'
I've included a screenshot of the issue. Is there any way to figure out what's wrong? I would really love to be able to have all the episodes on my computer.
Re: Lost S01E24 keeps failing
Post by Woodstock » Wed Mar 04, 2015 5:53 am
Your drive is saying it can't read the disk at that point. Even though it is new, clean it - BD is very sensitive to finger prints!
tatts4Life
Post by tatts4Life » Wed Mar 04, 2015 12:11 pm
OMFG so I first read your post this morning and laughed because it seemed like that would be the stupidest thing to cause an issue. Well I grabbed my disc and looked and wouldn't you know it there was a thin line of junk starting from the center and going about an inch long. It was real thin and light so I wouldn't of thought that would cause an issue. It reads just fine in my bluray player. Anyways I clean it off with a Kleenex and it works just fine now. Thanks for the stupid simple fix. I wouldn't of even thought of that being an issue.
Post by Woodstock » Wed Mar 04, 2015 3:12 pm
Things happen.... we understand.... ;)
Hint - do NOT use tissues. They're far too abrasive. Microfiber cloth, or soft cotton rags, are MUCH safer.
tatts4Life
Post by tatts4Life » Wed Mar 04, 2015 3:48 pm
I used the cloth I use for my glasses. It's a microfiber cloth.
