LPCM Codec ID issue
spl147
LPCM Codec ID issue
#1 Post by spl147 » Tue Jan 06, 2015 3:43 am
i noticed that none of my MKV's with LPCM tracks play audio on my mac or on my mede8er. after some digging aroung i found that the codec id in the MKV was "A_MS/ACM" i changed it to "A_PCM/INT/LIT" and now i have audio.
is this something that mike can fix?
info was taken from here:http://www.mede8erforum.com/index.php?topic=10809.0
Re: LPCM Codec ID issue
#2 Post by mike admin » Sun Jan 11, 2015 11:27 am
Just use FLAC profile.
crussader
#3 Post by crussader » Wed Feb 25, 2015 1:58 am
How is the FLAC profile selected?
#4 Post by Woodstock » Wed Feb 25, 2015 5:44 pm
Go to Preferences, General, and check "expert mode".
Once that is checked, you can select the profile to use on the main screen before you start the extract, and you can also change which profile is the default (that's in Preferences -> Advanced, which will appear after Expert mode is turned on).
crussader
#5 Post by crussader » Wed Feb 25, 2015 6:08 pm
