Cannot decrypt The Desolation of Smaug
simong
Post by simong » Thu Feb 19, 2015 10:56 pm
I have just bought a USB BD drive to see if I can rip BluRay disks and watch them on my computer. I only have one - The Desolation of Smaug. There was a discussion about this title last year with an older version of makemkv but I'd like to know what the status is now. Although I can successfully rip the disc I can decrypt it and therefore can't watch it.
Log file attached - any ideas on how to overcome this problem gratefully received.
***Correction: I tried to add the log file but got:
Sorry, the board attachment quota has been reached.
Here it is inline:
simon@localhost ~]$ cat MakeMKV_log.txt
Debug log started at Thu Feb 19 17:45:57 2015 , written by MakeMKV v1.9.1 linux(x64-release)
001005:0000 MakeMKV v1.9.1 linux(x64-release) started
001004:0000 Debug logging enabled, log will be saved as /home/simon/MakeMKV_log.txt
DAFD=PAAAADAAAAEABDQEEAQEBAQ==
001003:0020 DEBUG: Code 0 at !s8Qu#!=(X"m|#xyt:213130582
001003:0020 DEBUG: Code 0 at BJ8F{OS?&x{Z8\,^9(:29395195
001003:0020 DEBUG: Code 0 at BJ8F{OS?&x{Z8\,^9(:121262647
001003:0020 DEBUG: Code 1 at BJ8F{OS?&x{Z8\,^9(:121262647
001003:0020 DEBUG: Code 2 at BJ8F{OS?&x{Z8\,^9(:121262647
001003:0020 DEBUG: Code 3 at BJ8F{OS?&x{Z8\,^9(:121262647
001003:0020 DEBUG: Code 4 at BJ8F{OS?&x{Z8\,^9(:121262647
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0274B6810D109560EED7B575451B54D32A2 to device 'SG:dev_11:1'
001003:0020 DEBUG: Code 0 at !s8Qu#!=(X"m|#xyt:213130766
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..05078CFE736A0FB7568A50F45F2C958B1E5 to device 'SG:dev_11:1'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0D37ABC920496107C0FD38492AEEFC0B702 to device 'SG:dev_11:1'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0271DC1DA179D8A44DD8CC4179A783FE1A5 to device 'SG:dev_11:1'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..06DAE8B3F88F8C2737F00743E5A93F93A57 to device 'SG:dev_11:1'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'SG:dev_11:1'
DEBUG: Code 0 at !s8Qu#!=(X"m|#xyt:213130306
001003:0020 DEBUG: Code 0 at BJ8F{OS?&x{Z8\,^9(:29396345
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..058969521293931B9AE93E916D4044F39FE to device 'SG:dev_11:1'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..076A4DA15D562FE37A0F8F88AF971FF7E4C to device 'SG:dev_11:1'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..015DEC9BE22C15DF5477B69A63473C07F70 to device 'SG:dev_11:1'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..07D7BAA0FC37BBA025000717E46D5752976 to device 'SG:dev_11:1'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..06127C0EA8275D4079AC625CFFA80D6A1E6 to device 'SG:dev_11:1'
003306:0000 Can't read AACS VID from disc - most likely current AACS host certificate is revoked by your drive
003341:0000 Highest AACS version is v46 , MKB saved as /home/simon/.MakeMKV/MKB_v46_THE_HOBBIT_DESOLATION_OF_SMAUG.tgz
003303:0000 The volume key is unknown for this disc - video can't be decrypted
001003:0020 DEBUG: Code 0 at .&:+:k~<nm6=d1H(:213131985
001003:0020 DEBUG: Code 0 at .&:+:k~<nm6=d1H(:121265407
Re: Cannot decrypt The Desolation of Smaug
Post by Woodstock » Fri Feb 20, 2015 2:20 am
I think the key is here:
Something in Linux is preventing MakeMKV from communicating directly with the drive, to send the key.
While I am never a fan of running things as superuser when they can be done without that privilege, does it work if you run MakeMKV as root?
simong
Post by simong » Fri Feb 20, 2015 6:46 pm
Thank you for the suggestion. I tried it but got the same type or errors:
[root@localhost ~]# cat MakeMKV_log.txt
Debug log started at Fri Feb 20 18:41:16 2015 , written by MakeMKV v1.9.1 linux(x64-release)
001004:0000 Debug logging enabled, log will be saved as /root/MakeMKV_log.txt
005072:0000 Backing up disc into folder "/root/Videos/backup/THE_HOBBIT_DESOLATION_OF_SMAUG"
005050:0000 Evaluation version, 30 day(s) out of 30 remaining
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..044F56EBAEEE20AF2FCD280CDE5A751BC34 to device 'SG:dev_11:1'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..077CC9E5E9D28BAAC2DED6213840B30EAE5 to device 'SG:dev_11:1'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0778DEEBDDFA9450D58A2086DBDAC5E5E15 to device 'SG:dev_11:1'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..033C158E8212598ECC4559AD46BFEC6C5D6 to device 'SG:dev_11:1'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..08A4DF1E8A34A8307B5C5940E0430593CF0 to device 'SG:dev_11:1'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..03C4A65E0C51FC0CAE442F3A483CD56D2E7 to device 'SG:dev_11:1'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..02DFB1F880E0F3A0447881A418C82FCDAED to device 'SG:dev_11:1'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..04BCE28F7CF537CE8233692E175DBB25CEC to device 'SG:dev_11:1'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..083629125B421B4FE1D8CAE6FBA064F43E4 to device 'SG:dev_11:1'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..02F1F63385B31224F8AEA59F5239CCAEB7C to device 'SG:dev_11:1'
003341:0000 Highest AACS version is v46 , MKB saved as /root/.MakeMKV/MKB_v46_THE_HOBBIT_DESOLATION_OF_SMAUG.tgz
001003:0020 DEBUG: Code 0 at r(I^Ona_,`d]&U"ay3G:29403889
001003:0020 DEBUG: Code 0 at b-!hNPw/-zpyjvHG0<\.:29396851
005069:0080 Backup failed
005080:0204 Backup failed.
Application exited at Fri Feb 20 18:42:55 2015
Post by Woodstock » Fri Feb 20, 2015 8:49 pm
I'd suggest sending the TGZ file the log points to to Mike at svq@makemkv.com , just in case.
Right now, we'll have to wait for Mike to see this, as he can tell if the debug messages point to the solution.
simong
Post by simong » Mon Feb 23, 2015 5:51 pm
Thanks, I have sent the file by email as you suggested.
