Can ISO menu from ripped DVD be accessed by Android touch?
joewilde
#1 Post by joewilde » Sun Feb 15, 2015 7:17 am
What I'm trying to do is used a ripped DVD on an Android tablet. I can get the DVD menu system to work but it only works with the inbuilt DVD player remote. Is there a way I can get the DVD menu to operate by using the touchscreen? I'd like to use the touchscreen to pick the buttons rather than running through this remote.
Re: Can ISO menu from ripped DVD be accessed by Android touc
#2 Post by Woodstock » Sun Feb 15, 2015 7:28 am
What does this have to do with MakeMKV? MakeMKV does not "do" ISO rips.
And players that play ISO rips are going to require a lot of bandwidth to do so on Android, unless it's a local file.
Your best bet would be to search the Android market for players that support ISO playback, and ask their support people if they do menus....
joewilde
#3 Post by joewilde » Sun Feb 15, 2015 7:36 am
I understand that I was just hoping someone could help out if they perhaps knew of a way it could be done. I'm not worried about bandwidth, I made a DVD to help children with intellectual challenges and am distributing it as a free download, it has a DVD created menu system that works for the television but it would be great to install it on tablets. I have searched high and low on the internet and just thought if I ask as many people as I can then someone would know how to do this.
Thanks for your time in answering my question, I will do as you suggested.
