Can ISO menu from ripped DVD be accessed by Android touch?
joewilde
Post by joewilde »
What I'm trying to do is used a ripped DVD on an Android tablet. I can get the DVD menu system to work but it only works with the inbuilt DVD player remote. Is there a way I can get the DVD menu to operate by using the touchscreen? I'd like to use the touchscreen to pick the buttons rather than running through this remote.
Re: Can ISO menu from ripped DVD be accessed by Android touc
What does this have to do with MakeMKV? MakeMKV does not "do" ISO rips.
And players that play ISO rips are going to require a lot of bandwidth to do so on Android, unless it's a local file.
Your best bet would be to search the Android market for players that support ISO playback, and ask their support people if they do menus....
joewilde
Post by joewilde »
I understand that I was just hoping someone could help out if they perhaps knew of a way it could be done. I'm not worried about bandwidth, I made a DVD to help children with intellectual challenges and am distributing it as a free download, it has a DVD created menu system that works for the television but it would be great to install it on tablets. I have searched high and low on the internet and just thought if I ask as many people as I can then someone would know how to do this.
Thanks for your time in answering my question, I will do as you suggested.
