The Maze Runner no FUTs
BUTTON
#1 Post by BUTTON » Fri Feb 13, 2015 12:12 pm
As the title says the newly released UK The Maze Runner is displaying no FUTs using latest version 1.9.1.
Not a bad bit of software though, been using Pavtube for years but recently they are really far behind with new encryption releases.
How does MakeMKV deal with new encryption releases? Does it incorporate fixes in new versions of is it sorted at the server end and whatever version you have accesses keys via the net?
i.e, when a new encryption is broken does the version you have become able to access that or must a newer version be installed?
MakeMKV v1.9.1 win(x64-release) started
Backing up disc into folder "*************"
Loaded 17 SVQ file(s)
Processing BD+ code, please be patient - this may take up to few minutes
Processing BD+ code using generic SVQ from builtin/00000.svq
Saved BD+ dump file as D:\TV Capture/dump_The_Maze_Runner_5905C4C3A8D3943E_D.tgz
ndjamena
Re: The Maze Runner no FUTs
#2 Post by ndjamena » Fri Feb 13, 2015 1:18 pm
Workarounds for BD+ are downloaded, otherwise you need to install a new version.
