BD+ error by the Movie Doktorspiele
weisnet
Post by weisnet » Thu Feb 12, 2015 7:02 pm
I get an BD+ error by "Doktorspiele" "BD+ Code wurde bearbeitet, aber es wurde keine FUTs erstellt...."
Protecton:AACS v47, BD+ v2014.12
What can i do?
Thanx for Answers...
Re: BD+ error by the Movie Doktorspiele
Post by Woodstock » Thu Feb 12, 2015 8:52 pm
If the AACS is that old, usually MakeMKV would have been updated for the BD+ on the disk. Are you using the latest version? Do you have MakeMKV set to automatically update its SVQ files?
http://www.makemkv.com/svq/
If you are on 1.9.1, you need to send the TGZ file that was listed in your log to svq@makemkv.com , per http://www.makemkv.com/svq/
Romansh
Post by Romansh » Thu Feb 12, 2015 11:10 pm
Woodstock wrote:If the AACS is that old, usually MakeMKV would have been updated for the BD+ on the disk.
Not necessarily. Wasn't it Star Wars that used as very old AACS version but the very latest BD+?
weisnet
Post by weisnet » Fri Feb 13, 2015 12:32 am
Yes im on the newest Version of MakeMKV. I have send the Mail with the *.tgz file.
Thanx for the fast help.
weisnet
Post by weisnet » Fri Feb 13, 2015 8:06 pm
how long will it take until I can rip the Bluray ?
Post by Woodstock » Fri Feb 13, 2015 8:45 pm
It will depend on when Mike gets your message and has time to make the SVQ file.
If you have automatic updates enabled, try ripping the disk in a couple of days. Usually, Mike doesn't make announcements about creating the SVQ; rips just start working.
weisnet
Post by weisnet » Fri Feb 13, 2015 8:50 pm
where exactly do I keep the one autoupdate ?
Post by Woodstock » Sat Feb 14, 2015 12:37 am
Under Preferences, General, make sure "Allow contacting web server for updates" is checked.
weisnet
Post by weisnet » Sat Feb 14, 2015 6:26 pm
Thanx it Works! Great!
