La Dolce Vita, 8 1/2 Blu-ray
Rip Murdock
Post by Rip Murdock » Sat Feb 07, 2015 9:31 pm
La Dolce Vita rips with no audio track.
8 1/2 rips with two audio tracks, but the Italiano auido track has no sound. The English Commentary track plays fine.
I'm using the latest version MakeMKV Beta.
Thanks.
Re: La Dolce Vita, 8 1/2 Blu-ray
Post by Woodstock » Sat Feb 07, 2015 11:44 pm
Debugging logs would be VERY helpful. What are you using to play the files?
When you open the disk, next to each title in the left window there is a small triangle. Click on it to show the individual tracks within the title, and make sure you have a compatible audio stream selected.
Ripman
Post by Ripman » Sun Feb 08, 2015 2:08 pm
I ripped both CR BDs without issue. The "main" audio tracks are LPCM in Italian mono. Does your player support LPCM in MKV (e.g., Sony players do not)?
Also, if your default language is set as "English," then the Italian LPCM audio tracks may not be checked when you open the BD index. Use the plus sign to open the appropriate title, and check the LPCM Italian mono box.
Post by Woodstock » Sun Feb 08, 2015 8:56 pm
There was an issue with an older version of MakeMKV not being able to rip mono LPCM tracks - that was fixed before 1.9.0 came out.
Again, this would show up in the logs, along with the version of MakeMKV in use.
Rip Murdock
Post by Rip Murdock » Thu Feb 26, 2015 11:01 pm
Yes, it was the media player. VLC plays the Italian audio tracks just fine. PowerDVD does not. Thanks for your help.
