there is no BluRay decrypted
compi
#1 Post by compi » Fri Feb 06, 2015 7:06 am
Hi my englisch is verry bad.
My Problem MakeMKV always aborts with the same error messages.
My System:
Lubuntu 14.10 64bit
MakeMKV v1.9.1 linux(x64-release)
OS device name: /dev/sr1
Manufacturer: Optiarc
Product: BD RW BD-5850H
Revision: 1.00
Serial number: 1001686E112
The BD-Rom LW is connectet over USB.
under Windows 8.1 64bit works makemkv good, with the same BD-Rom LW to USB.
Thanks compi
Debug log started at Fri Feb  6 06:58:29 2015 , written by MakeMKV v1.9.1 linux(x64-release)
001005:0000 MakeMKV v1.9.1 linux(x64-release) started
001004:0000 Debug logging enabled, log will be saved as /home/lars/MakeMKV_log.txt
001003:0020 DEBUG: Code 4 at <kW+~YPDAr.]s:213130122
001003:0020 DEBUG: Code 0 at ,v>-4%$f=SaQ7fh:,:213130306
001003:0020 DEBUG: Code 0 at ,v>-4%$f=SaQ7fh:,:29394873
DAFD=PAAAADAAAAEABDQkEGwEEAQ==
001003:0020 DEBUG: Code 0 at !s8Qu#!=(X"m|#xyt:213130582
001003:0020 DEBUG: Code 0 at BJ8F{OS?&x{Z8\,^9(:29395195
001003:0020 DEBUG: Code 0 at BJ8F{OS?&x{Z8\,^9(:121262647
001003:0020 DEBUG: Code 1 at BJ8F{OS?&x{Z8\,^9(:121262647
001003:0020 DEBUG: Code 2 at BJ8F{OS?&x{Z8\,^9(:121262647
001003:0020 DEBUG: Code 3 at BJ8F{OS?&x{Z8\,^9(:121262647
001003:0020 DEBUG: Code 4 at BJ8F{OS?&x{Z8\,^9(:121262647
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'SG:dev_11:1'
DEBUG: Code 0 at !s8Qu#!=(X"m|#xyt:213130306
001003:0020 DEBUG: Code 0 at BJ8F{OS?&x{Z8\,^9(:29396345
003306:0000 Can't read AACS VID from disc - most likely current AACS host certificate is revoked by your drive
003341:0000 Highest AACS version is v8 , MKB saved as /home/lars/.MakeMKV/MKB_v8_RUBY_UND_QUENTIN.tgz
003303:0000 The volume key is unknown for this disc - video can't be decrypted
001003:0020 DEBUG: Code 0 at .&:+:k~<nm6=d1H(:213131985
001003:0020 DEBUG: Code 0 at .&:+:k~<nm6=d1H(:121265407
Re: there is no BluRay decrypted
#2 Post by Woodstock » Fri Feb 06, 2015 11:22 pm
It would appear that Linux is not allowing MakeMKV enough control over the drive to communicate the decryption key. Are you running it with root privileges?
richEQ
#3 Post by richEQ » Fri Feb 27, 2015 6:34 pm
It does look like this is a permanent bug in this program.
Has anyone had makemkv work under Linux?
Does any one know of any open source alternatives?
#4 Post by Woodstock » Fri Feb 27, 2015 10:20 pm
Well, for it to be a "permanent bug in the program", there would be a lot more people experiencing it, but there only seem to be a handful.
richEQ
#5 Post by richEQ » Sat Feb 28, 2015 9:35 am
Hi Woodstock! thanks for you help last time when I had this same issue.
<pedant>Not sure I receved an answer as to whether anyone has had this working under linux. :-/ </pedant>
Is anyone in a position to spot what combination of set up details are causing the fail?
is it kernel version, libs, blu hardware??
There was little responce from the guy at the end of the bug email I sent, so not sure how else I can help fix the bug.
The error log is not particularly helpfull for anyone without the key to decipher....
EgLe01
#6 Post by EgLe01 » Sat Mar 14, 2015 3:50 pm
i have try this Tool under my Kubuntu LTS 04.14
egle@i7-core-4770:~$ uname -a
Linux i7-core-4770 3.13.0-46-generic #79-Ubuntu SMP Tue Mar 10 20:06:50 UTC 2015 x86_64 x86_64 x86_64 GNU/Linux
This Tool works perfect by Isofiles so theres no cypted.
For test i have by my first BluRay for 3 Euro gg
And i have by my new Diskdrive "QUMOX USB 3.0 Blu-Ray BD Brenner Slim USB Notebook "
So i get the same Message vs. the first posting...
see in the attachment the logfile. :-)
So my english is very ugly too, but if i can i will to help...
PS: sorry i am to stupid to uplaod the Logfile, or the Forumsoftware ist missmatch....
So here the log:
Debug log started at Sat Mar 14 15:34:15 2015 , written by MakeMKV v1.9.1 linux(x64-release)
001005:0000 MakeMKV v1.9.1 linux(x64-release) gestartet
001004:0000 Debug-Aufzeichnung eingeschaltet. Aufzeichnung wird gespeichert als /home/egle/MakeMKV_log.txt
003007:0000 Direkter Zugriffsmodus wird verwendet
005050:0000 Evaluierungsversion. Es verbleiben noch 11 von 30 Tagen.
DAFD=PAAAADAAAAEABDQkEGQEBAQ==
002004:0000 Fehler 'SCSI-Fehler - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' trat auf während der Übertragung des SCSI-Befehls AD010..0800024C0 zu Laufwerk 'SG:dev_11:0'
003306:0000 AACS-VID kann nicht gelesen werden - höchstwahrscheinlich wird das AACS-Hostzertifikat durch Ihr Laufwerk aufgehoben
003341:0000 Highest AACS version is v30 , MKB saved as /home/egle/.MakeMKV/MKB_v30_IMMORTAL.tgz
003303:0000 Der Volumenschlüssel für die DVD/Blu-ray ist unbekannt - das Video kann nicht entschlüsselt werden
005010:0000 Das Öffnen der Disk schlug fehl
Application exited at Sat Mar 14 15:49:37 2015
I have try this as users and as root too, ist the same errrormessage
in Terminal to start from root, i can see this to:
egle@i7-core-4770:~$ sudo makemkv
[sudo] password for egle:
Error: "/var/tmp/kdecache-egle" is owned by uid 1000 instead of uid 0.
Bus::open: Can not get ibus-daemon's address.
IBusInputContext::createInputContext: no connection to ibus-daemon
Object::connect: No such signal org::freedesktop::UPower::DeviceAdded(QDBusObjectPath)
Object::connect: No such signal org::freedesktop::UPower::DeviceRemoved(QDBusObjectPath)
Error: "/tmp/ksocket-egle" is owned by uid 1000 instead of uid 0.
Error: "/tmp/kde-egle" is owned by uid 1000 instead of uid 0.
sure, i pay not for Tools they doesn't work :(
