New activation code till end of March 2015 doesn't work
critical
Re: New activation code till end of March 2015 doesn't work
#31 Post by critical » Tue Feb 03, 2015 10:10 am
onthebeach wrote:I was experiencing the same issue today. I remembered I had previously updated to 1.9.1 in January.
The workaround I successfully used:
1. I grabbed the previous version 1.9.0 from: /download/old/
2. Uninstalled 1.9.1
3. Installed 1.9.0
4. Registered the new key
5. Confirmed the package was working
6. Installed 1.9.1 again
7. Confirmed software id working as normal.
I can confirm that this workaround worked for me. Thank you for sharing.
Assmonkey
#32 Post by Assmonkey » Tue Feb 03, 2015 10:49 am
3. Installed 1.9.0
Does not work for me.
Rustle
#33 Post by Rustle » Tue Feb 03, 2015 11:39 am
3. Installed 1.9.0
This has worked for me too!
As of today, 3rd Feb, I have until Tue March 31st, 55 days left of 1.9.1, which is correct!
Not sure on the issue, but the activation code does work! (eventually)
sparktank
#34 Post by sparktank » Tue Feb 03, 2015 12:46 pm
The beta key has been updated and works on current 1.9.1 version.
No need for work arounds anymore.
ssizzl
#35 Post by ssizzl » Tue Feb 03, 2015 2:09 pm
Thanks to MakeMKV! I am once again working with the new key.
IanSurrey
#36 Post by IanSurrey » Tue Feb 03, 2015 5:12 pm
Me too,
Downloaded the latest version: Says register and place the activation code only for it to delete it on start-up.
NEO Dan
#37 Post by NEO Dan » Tue Feb 03, 2015 6:30 pm
3. Installed 1.9.0
This appears to work. It would be nice to know if the 1.9.1 package was fixed and reposted though...
zapultin
#38 Post by zapultin » Tue Feb 03, 2015 9:47 pm
as of "right now" the new key works in my "old" install 1.9.1 (already installes 31.1.)
eelisland
#39 Post by eelisland » Wed Feb 04, 2015 5:57 pm
Thanks new beta key work with current date!
SpaceCowboy
#40 Post by SpaceCowboy » Wed Feb 04, 2015 8:22 pm
Hmm. No problems with activating 1.9.1 again with the new key. I'm using Win7x64 and updated from 1.9.0 on the day of the release.
